Old 09-10-2009, 12:36 PM   #1 (permalink)
Default Problem With Laptop
Hi friends
I use a Compaq,V3000 series Laptop with Vista Home. Athlon X2,512mbx2 RAM. Its 2 years old and well kept and looked after with antivirus etc.
About 10 days back I started getting a message from Microsoft Office saying"your MS Office is not genuine" etc etc. Since it had a irritating value I asked my supplier to change the Office and he loaded a newer version of Office. The message has stopped coming. However another problem has also cropped up alongwith this is that now everytime I "Power-On' my laptop the screen remains blank. Then I have to "Power-Off" it 2-3 times to get it working.
Do you figure out what the problem is ??
My supplier feels that since the battery is very weak now, it may be caused by that. What do you think. Kindly advise. I shall wait for your inputs before I call Hphelp.
Thanks
harmads is offline
Old 09-10-2009, 02:47 PM   #2 (permalink)
Default Re: Problem With Laptop
Talk to HP customer care and see what they say.
How long have you kept the laptop on with blank screen? Is it that you don't even see the POST screen?
hell_storm2006 is offline
Old 10-10-2009, 01:09 PM   #3 (permalink)
Thanks for the reply..what is POST screen ? plz elaborate.
This phenomenon happens every time I switch my comp on, since I shut it down if I dont use for long durations.
harmads is offline
Old 11-10-2009, 03:33 PM   #4 (permalink)
johnrosswrock
Posts: n/a
hi friends,
since today my laptop not working properly
it is showing a message "no system disk" and my hard disk makes noise when ever i switch on my laptop.following r the system config
compaq nx6120
centrino processor, 256 mb ram 40 gb hard disk
windows xp
please help
Posted again:
harmads
POST screen is the BIOS screen
Last edited by johnrosswrock; 11-10-2009 at 03:38 PM. Reason: Automerged Doublepost
Old 11-10-2009, 05:00 PM   #5 (permalink)
Cool G5's Avatar
@johnrosswrock - HDD making noise is a sure sign of a failing HDD. Replace the HDD & stop using the laptop to avoid any further damage to your HDD & data.
Cool G5 is offline
Old 13-10-2009, 10:02 AM   #6 (permalink)
johnrosswrock
Posts: n/a
@cool G5 - thank for helping but can u tell me, if it is possible to retrieved data form this HDD.
Old 13-10-2009, 10:17 AM   #7 (permalink)
Cool G5's Avatar
Offcourse it is possible.
Backup data as soon as possible as it may die any moment.
Cool G5 is offline
- by bhaskar
