Old 09-10-2009, 08:03 AM   #1 (permalink)
Default Good Cabinet around 2k or less
My Config is in my sig.
Will be adding a HDD soon.
iBall- Gamer and CM Elite 330 looks nice
I dont OC or CF/SLI
Posted again:
Looking for a Space for new GTS fitting confortably as right now its cramped.
Also future prrofing of adding a couple more HDDs
Phenom II 955 BE @ 4.12 Ghz | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Seagate : 1 TB | NZXT Phantom 410
Elite 335 Cabinet @ 0.8K http://www.thinkdigit.com/forum/baza...ite-335-a.html
Tech_Wiz is offline
Old 09-10-2009, 08:50 AM   #2 (permalink)
Crowman
Krow's Avatar
Default Re: Good Cabinet around 2k or less
Cooler Master Elite 330 is a good cabby, iBall doesn't come close.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 09-10-2009, 08:55 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Forget about iball. my pick would be CM Elite 330 or 331 (without PSU) and Zebronics Reaper or Bijli (without PSU).
desiibond is offline
Old 09-10-2009, 10:07 AM   #4 (permalink)
Super Moderator
asingh's Avatar
As all have recommended.
Coolermaster is leagues ahead of i-ball. Go ahead with full confidence
asingh is offline
Old 09-10-2009, 12:29 PM   #5 (permalink)
harryneopotter's Avatar
CM elite 330/331/334/335 ... all come within 2k ... so its ur choice now !!!
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
harryneopotter is offline
Old 09-10-2009, 06:33 PM   #6 (permalink)
Bought CM Elite 330
Tech_Wiz is offline
Old 09-10-2009, 06:44 PM   #7 (permalink)
Crowman
Krow's Avatar
Give us some pics of your upgraded rig maannnnn!! We deserve a look.
Krow is offline
Old 09-10-2009, 07:05 PM   #8 (permalink)
Hehe I will Put Some comparison Pics like Old Thing and New Thing + Some step by step Pics
Tech_Wiz is offline
Old 10-10-2009, 05:28 PM   #9 (permalink)
Am here for u
Vensanga's Avatar
Can u also specify the price..is it also available with the transparent panel..Which do u guys think better..transparent or not transparent!!
Acer aspire TimelineX 4820T, Nokia 5800XM
Vensanga is offline
Old 10-10-2009, 11:48 PM   #10 (permalink)
Depends on user. Transparent ones looks better with LED Fans but are more susceptible for cracking / breaking. + On Metal ones you can Mod better/
Tech_Wiz is offline
Old 14-10-2009, 05:03 PM   #11 (permalink)
Update: They didnt had the 330 so I Bought 335 instead.
Switching from a El Cheapo Circle Cabinet (Single 80mm fan) + Circle PSU(400w) to CM Elite 335( CM 120mm - 2 fans) + Cosair VX450W was a very good experience.
Costed me 4 +2.3 = 6.3 k. Some might say thats a lot for these two most ignored and important parts but it was well worth it.
My components are feeling like moved from a Dharavi Hut to a Full Duplex hehe.
Very very roomy cabinet. Tool free. Can fit 5 HDDs with ease. Has washable air filter and sponge in front so not much dust can go in the cabinet. Some sharp edges in rear but for its price this is gold.
GTS 250 fitted easy with almost a couple inch to spare so I guess I wont be needing to change the cabinet or power supply for any single gfx out there
This is made of 1mm thk steel. Rock Sturdy. To compare we use 0.8mm thk sheet in Car panel mfg. (I am a Manager (Design) in TATA Engg Research Center. No risk of dents or bents.
ps: CM LED Fans 120 mm Rock ass.
I wish i could post some Pics right away but wife is gone with my Cam so will post later.
<--- Happy
Tech_Wiz is offline
Old 14-10-2009, 10:35 PM   #12 (permalink)
Crowman
Krow's Avatar
The build quality is great no doubt. Pics soon I hope.
Krow is offline
- by bhaskar
