08-10-2009, 04:56 PM
15.0 GHz
Suggest a sound card within 1k
hi friends,
my onboard sound got kaput, so I have decided to buy a sound card. Please suggest a good 5.1 sound card within the range of 1k.
08-10-2009, 06:26 PM
Re: Suggest a sound card within 1k
Under 1k, there isnt any reputable brand. Go to the local shop and pick anyone like Enter, Intex etc, which offers 5.1 sound at affordable prices, and shud sound slightly better than onboard.
G3: XPS M1530 |
FZ 16.
09-10-2009, 04:05 PM
15.0 GHz
then please suggest a reputable brand, which is the cheapest, doesn't matter below 1k
09-10-2009, 09:03 PM
Bond, Desi Bond!
I think Creative Live 7.1 is still available for some 1.1k-1.2k. Also check for Creative X-Fi XtremeMusic.
11-10-2009, 10:04 AM
15.0 GHz
thanks for the suggestion, i don't think Creative Live 7.1 is still avaliable, cuz i checked on google and there are no positive results, nor it is on Creative website.
Also can anybody quote the price of Creative X-Fi XtremeMusic.
hows Audigy?
11-10-2009, 10:33 AM
Bond, Desi Bond!
audigy too is a good product. audigy value is perfect for entry level audio
11-10-2009, 11:34 AM
15.0 GHz
whats the price of audigy?
11-10-2009, 11:54 AM
^^Is it available? Whats the approx price? Will it run on Win 7?
I am badly stuck with my Philips PSC605 5.1 Sonic Edge soundcard. The drivers are extinct for ages!!
13-10-2009, 08:01 AM
15.0 GHz
I asked prime abgb they told Creative 5.1 is available @ 1250/-, is it a good sound card?
13-10-2009, 11:01 AM
Asus Xonar DX 7.1 Channel Sound Card. 5k. Probably the best one available. There are more expensive flavours of this card. But this is the one you can go for.
13-10-2009, 11:09 AM
Bond, Desi Bond!
What exactly is that creative 5.1. Looks like they are trying to sell off a very old unsold product to you. being 5.1, it could be some 6-7 years old card.
14-10-2009, 12:23 AM
Project Halcyon V2.0
No they don't, I bought one from Enter and heck my onboard Realtek ALC1200 sounds a lot better, with Enter there was noise at high volumes and sound would crackle, never buy Enter stuff and Intex is The Devil incarnate, bought a headphone, wish I burned my 100/- note instead of buying it.
Project Halcyon v2.0:
16-10-2009, 10:18 AM
15.0 GHz
instead of going for ASUS Xonar i can, go for a new mobo, cuz i told already my onboard sound is kaput so, sound card is only the alternative.
23-10-2009, 08:58 PM
Which speakers are you using btw? If the speakers are crappy ones, I don't see any reason even to waste money on one- but your case is different. The only good alternate I could see is either you get a SB value 5.1 for second hand for 500-700 bucks odd (I am pretty sure putting up many of you guys would have it), save 1.7k more and get a g31 board- or see if the onboard sound could be repaired. I am not saying you shouldn't spend 1k on a sound card, but putting 1.7k more fetches you a better board- what if some other problem comes from the board and after you realise that the onboard going kaput is sort of a sign that the board is "dying", you will have to cough up money to get a new board- think about the alternates I am talking about. Value cards does give better sound than onboard- that's for sure. I do not know about compatibility with windows 7.
23-10-2009, 09:59 PM
Today i went to market and inquire about the sound card prices . He told me of 2 models that are currently available in Raipur(C.G)
Creative 5.1 (I think it is SB 5.1 or something like that ) - Rs 1.2k
Creative Audigy (He did not elaborate ) - Rs 1.8k
He suggested to me that as i have a 5.1 Speaker set (SBS A500) ,I should not go for audigy as it is meant only for 7.1 or 6.1 config and instead should invest on simple 5.1 as quality wise both are same (According to him ) and the only difference lies in no of pins (one extra for 7.1) and the sound difference can not be differentiated by ordinary ears .
I checked in their site and below are the links
Creative 5.1
Creative audigy value
both support EAX ,CMSS etc
and yes can any body could tell me the price of the below mentioned card and where can i buy it
Sound blaster 5.1 vx
So please suggest what should i get . I have also mentioned the speakers in case that is important . Please suggest me as i can literally save 500 to 600 rupees if I choose the right card.
There is No Dark & Light side of Force . There always has been,always will be & always has been,One & Only Ayushman
08-11-2009, 08:34 AM
I bought sound blaster 5.1 vx for 1000+VAT yesterday
P4 2.4 GHz Prescott;768 MB RAM;Seagate 80 GB PATA & 160 GB SATA;Creative Inspire 5200;ViewSonic E71f;256 MB Leadtek A6600TD;Logitech MX518;Microsoft Natural Ergonomic 4000
08-11-2009, 02:36 PM
Super Moderator
Creative 5.1
Just get the Creative Audigy Value. I had it on my last system (got it for around rs 1300 or something, 3 years ago). It supports 5.1 channels and EAX. It is a good card, and as the name suggests 'VALUE', it is a value card.
If you are not a music aficionado then this card is good. It is any day better then the RealTEK chips we get on most motherboards. I remember it rendered all highs and lows pretty well on my el-cheopo 2.1 speakers. (PROMAX)
08-11-2009, 03:29 PM
#19 (permalink)
<Sparkling Pwnies>
You won't get anything worthwhile for under 1k. Go for the Creative Audigy, it's really OK for the price, I would reccomend it as I use it... I got mine for 1.4K, sure it is cheaper now.
IDDQD IDKFA
08-11-2009, 09:38 PM
#20 (permalink)
Super Moderator
+1..is good.
