Old 07-10-2009, 06:31 PM   #1 (permalink)
LegendKiller's Avatar
Default Q9400 and Intel 45SPg MB-Good Combo?
I have homed in on the following combo for upgradation of my old rig as per my 20k bugdet.Plz advice
Intel Q9400 Processor,Intel 45SG Mboard,DD2 Ram-2gb....
I have Seagate's 160Gb 7200.9 HDD.My vendor is asking me whether its SATA compatible?
From my search it tells me it is....any suggestion for 250gb HDD?
In the Pic: The Great Sachin Tendulkar
LegendKiller is offline
Old 07-10-2009, 06:50 PM   #2 (permalink)
Default Re: Q9400 and Intel 45SPg MB-Good Combo?
Point 1: Dont go for Intel Mobo. Opt for Gigabyte they got much better features.
Point 2: Dont Buy Seagate. Go for WD or Samsung
Phenom II 955 BE @ 4.12 Ghz | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Seagate : 1 TB | NZXT Phantom 410
Elite 335 Cabinet @ 0.8K http://www.thinkdigit.com/forum/baza...ite-335-a.html
Tech_Wiz is offline
Old 07-10-2009, 07:15 PM   #3 (permalink)
Crowman
Krow's Avatar
@ Legendkiller Core i5 750 Proccy is available for 10.2k and a Gigabyte P55 mobo is available for 7.2k i think. Much better config for you. DDR3 Ram too! You don't need a gfx card? Me too against buying seagate, although 1TB Seagate @ 3925 bucks seems tasty.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 07-10-2009, 07:23 PM   #4 (permalink)
laborare est orare
Cilus's Avatar
My suggestion would be for AMD front. It will offer u much performance boost than Intel on the price tag u mentioned.
Here goes my suggestion:
Phenom II X4 955 3.2GHz B.E. @ 13k
Biostar TA785GE 128M @ 4.3k
Kingston 2GB DDR2 800MHz RAM @ 1k
Seagate Barracuda 7200.12 500GB @ 2.5k
Street price may be lower than the mentioned price. This machine will offer u extreme performance for any application. It is even better than the Q9650 with 12 MB L2 Cache.
But if u r an Intel fan and don't want AMD then go for the Intel Q9550 @ 11k instead of Q9400. The performance difference would be huge.
Cilus is online now
Old 07-10-2009, 07:36 PM   #5 (permalink)
Crowman
Krow's Avatar
^ Core i5 is better as a proccy @ 10.5k. Much more VFM! AMD Phenom and Q9400 beaten hands down! If OP does not want gfx card, core i5 is the way to go.
Krow is offline
Old 07-10-2009, 08:25 PM   #6 (permalink)
actually me too wanted to buy i5-750 with P55 mboard,but people here in delhi have no clue about it........
so forcebily i am going for this.............
ok,i will look for WD HDD and gigabyte mboard
Old 07-10-2009, 08:54 PM   #7 (permalink)
Excessive happiness
furious_gamer's Avatar
@OP
Get it from lynx or itwares. They're reliable e-shops. BTW Core i5 kick the all above config (Not sure abt the Phenom II X4, whether AMD kick Intels a$$ or vice-versa).
But i5 rig would be a best investment IMO, mainly for a new platform and new memory DDR3...
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is online now
Old 07-10-2009, 09:03 PM   #8 (permalink)
Super Moderator
asingh's Avatar
No need to get it from Nehru Place. They know nothing there..true.
Just order a P55 Motherboard and complimenting CPU - i5 from Lynx.
MSI and Gigabyte have two excellent motherboards.
MSI Link. You can get this for RS. 9738.
Gigabyte Link. You can get this for RS. 7350.
CPU Link. You can get this for RS. 10150.
Both of these boards are really good. Supporting the LGA1156 package. And channel data using DMI. You get DDR3 speed RAM, though at Dual Channel. They both also have to PCI.E 2.0 slots. Running at x16 with single card, and auto arranging to x8x8 with dual GPU. The best thing about these boards is that you can OC really well.
asingh is offline
Old 07-10-2009, 09:59 PM   #9 (permalink)
Crowman
Krow's Avatar
+1 to asigh and Gigabyte mobo.
Krow is offline
- by bhaskar
