Old 02-10-2009, 09:49 AM   #1 (permalink)
damnbadman666
damngoodman999's Avatar
Default Does Dual monitor decrease FPS in games ???
I have single TFT 19" inch monitor & 17" CRT monitor i want to connect those to GTX 260 while gaming in a single TFT means the other monitor stays stand by , so then the FPS will decease
TFT resolution 144 X 900
CRT resolution 1024 X 768
damngoodman999 is offline
Old 03-10-2009, 08:53 AM   #2 (permalink)
Crowman
Krow's Avatar
Default Re: Does Dual monitor decrease FPS in games ???
I can't say anything for sure, but you better try it out and check. You can be our in house expert on dual monitors.
IMO, theoretically it should be like alt-Tab function in windows, so I don't think there woud be any performance drop in games unless you do something in the other monitor as in gfx intensive app. Best to try it out and see what happens.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 03-10-2009, 08:59 AM   #3 (permalink)
Don Draper is coming back
vamsi_krishna's Avatar
There will be performance drops if you are running GFX intensive apps in both the monitors. Rest is up with your CPU. If you are using 64 bit Operating system.. it will give better performance than 32 bit.
I am MaxPayne. My Wife and Daughter were murdered.
vamsi_krishna is offline
Old 03-10-2009, 11:30 AM   #4 (permalink)
Super Moderator
asingh's Avatar
Probably not. Since the GPU has all ready done the processing, it would just copy it across to a second output port. I am sure the chip is smart enough to do this.
Posted again:
Probably not. Cause the processing has all ready been done. It will just be copied to another port. Am sure the chips are smart enough to do this.
asingh is offline
Old 03-10-2009, 04:03 PM   #5 (permalink)
damnbadman666
Im using 64bit OS only !
Asigh - if i start the game the other monitor automatically turns off , again i quit the game the monitor power on . Only one monitor is used for gaming !
My GPU temp with one monitor is 48Deg if i connect another monitor it goes 54deg , that means wat ??
Old 03-10-2009, 05:26 PM   #6 (permalink)
Crowman
Krow's Avatar
The other monitor consumes power IMO.
Krow is offline
Old 03-10-2009, 08:49 PM   #7 (permalink)
Super Moderator
asingh's Avatar
How have you connected the monitors..also which games you tried..?
asingh is offline
Old 03-10-2009, 09:06 PM   #8 (permalink)
damnbadman666
one is with DVI another one with VGA (by using DVI to VGA connector) , all most all the games i tried .
Old 04-10-2009, 12:21 AM   #9 (permalink)
Super Moderator
asingh's Avatar
Which ones...names..??
asingh is offline
Old 05-10-2009, 01:31 AM   #10 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Simple logic. Each monitor has different resolution. You stress GPU more when resolution is higher so temps also go higher.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 05-10-2009, 03:57 AM   #11 (permalink)
damnbadman666
^^ nice MHG ,after long time good answer finally . wat abt the FPS drop in dual monitor while gaming ??
Old 05-10-2009, 04:32 AM   #12 (permalink)
The Smaller Bang
FPS should theoritically be unaffected whether the 2nd monitor is connected or not. Why can't you just try that part yourself and confirm ?
Old 05-10-2009, 09:53 AM   #13 (permalink)
Super Moderator
asingh's Avatar
Even I had mentioned...that. GPU does not get stressed via multi monitor. It is only the resolution and affects selected that stress the GPU.
asingh is offline
Old 05-10-2009, 02:04 PM   #14 (permalink)
damnbadman666
ya , now iam using single monitor so much for the dual one !
Old 06-10-2009, 01:54 PM   #15 (permalink)
maverick786us's Avatar
No, it won't, as the game simply won't render for the unactive monitor (some games, such as Supreme Commander, and World in Conflict, will render for the second screen), thus, to the game, the second monitor never existed.
(Gaming Rig) Intel E8400 @ 3.6Ghz, ASUS P5Q Pro, 4GB G.Skill DDR2 800, WD 6400AAKS HDD, MSI Cyclone GTX 460, Corsair 650TX, CM 690, Dell SP2208WFP (22 inch), Windows 7 Ultimatum 64
maverick786us is online now
- by bhaskar
