26-09-2009, 10:16 PM
AMD - Aaja Meri Darling
LCD Panel query
Just wanted to know which would be the best LCD panel to use (DVI Input) within 10K.
main priority is Photoshop CS3 and Movies.
Oh and budget can vary from time to time sooo
Could anyone list the best displays / price range ?
Under 7k
7-8k
8-9k
9k-10k
10k-12k
AMD Athlon II X4 620 | ASUS M4A785TD-V EVO - 785G
26-09-2009, 10:23 PM
Crowman
Re: LCD Panel query
For 7k, the best display is Samsung 2033SW IMO.
AOC Fovi F22 @ 8.8k
Samsung 2233SW @ 9.2k
Dell 2209W @ 9.2k
All these are cool monitors. But if you want my personal best recommendation for 10-20k, I will say Dell E2209WA, although I dnno the price. It is by far the best and most VFM LCD monitor around in terms of price to performance ratio.
26-09-2009, 10:58 PM
Re: LCD Panel query
Dell E2209WA ... what's the difference between Dell E2209WA & E2209W ?
27-09-2009, 03:03 AM
Re: LCD Panel query
Just wonder what's its exact price
Now I gotta save up more
27-09-2009, 11:17 AM
Crowman
Re: LCD Panel query
^Yeah, the price is about 16k AFAIK, but availability is less.
27-09-2009, 12:54 PM
Re: LCD Panel query
no other IPS panel in this kinda price either
thanks for the info though
27-09-2009, 01:27 PM
Super Moderator
Re: LCD Panel query
There is a 24" DELL available for 12K...at Tech Enclave
27-09-2009, 02:15 PM
Crowman
Re: LCD Panel query
asigh AFAIK that deal was closed.
27-09-2009, 03:09 PM
Super Moderator
Re: LCD Panel query
Seems open to me.
http://www.techenclave.com/dealers-paradise/dell-s2409w-12750-shipped-dell-u2410-144546.html
27-09-2009, 06:33 PM
Crowman
Re: LCD Panel query
^Ah great, but it takes weeks to deliver as Ethan_Hunt can verify. In between I had seen the deal was on hold/closed. But anyway, better get it from your local store @ 13k.
27-09-2009, 08:54 PM
Super Moderator
Re: LCD Panel query
Yea..it seems Ethan has still not got it.
But local stores do not host DELL products, specially the panels. And at 13K -- 24" is a killer deal.
27-09-2009, 11:04 PM
Re: LCD Panel query
Wht abt samsung lavender series p2350 moniter @ 11.4k...'
Its full hd and hdmi,dvi also...'
28-09-2009, 12:47 PM
Re: LCD Panel query
24" for 13k is still O_O ! .. hrm I havent even come across the Dell 2209WA which should be around like at 16k
and aren't the samsung lavender series 23.x" ? what's the resolution of the p2350 ?
28-09-2009, 02:55 PM
Re: LCD Panel query
Best Monitor for the price 16K - 2209WA. Since you are using this for photoshop CS3 purpose, you've got no other choice. Rest all are crap (for photoshop purpose, not for movies/daily usage).
2209wa advantages:
Deep blacks.
Superb contrast.
Great Viewing angles.
And other features like pivot, swivel etc.,
Intel D930&945GNTL| 2x1GB 667 Mhz(Transcend+Kingston)| 500GBSeagate+200 GB WD|Zotac 9600GT Amp!| Zebronics Platinum 400W|Dell SP2208WFP|Logitech z5500| Lite-onDVD-RW+LGDVD-R
28-09-2009, 06:12 PM
Re: LCD Panel query
Yep... 16k is over the budget but ill try to get that. Otherwise ill go in for the 2209W for 9.2k
28-09-2009, 10:28 PM
Crowman
Re: LCD Panel query
You may even have a look @ Samsung 2233SW, which is pretty good too IMO
29-09-2009, 12:32 AM
Re: LCD Panel query
While that is there, how much would I need to shell on a graphics card (ATi) to support such high resolutions ? Full HD is quite something
29-09-2009, 09:58 AM
#19 (permalink)
Crowman
Re: LCD Panel query
Nope. Unless you want to game at those high resolutions.
29-09-2009, 01:56 PM
#20 (permalink)
Re: LCD Panel query
Nah I wont be gaming beyond 1180x780.
I guess ill shell out more on some better ram (4GB-6GB) ..
29-09-2009, 09:35 PM
#21 (permalink)
Crowman
Re: LCD Panel query
Xeno, unless you NEED a monitor, do not buy it. CRT's are the best monitors of today unless you consider their bulky appearance and more power consumption. Their performance and viewing angles are better than all LCD's anyway. Better invest on RAM and wait for LCD's like 2209WA to be available for sub 10k and then invest wisely.
30-09-2009, 12:03 AM
#22 (permalink)
Re: LCD Panel query
Well this one was doing fine however the screen has become green in a corner, dont know how. So I do need a new monitor when the wallet allows
Not going to buy it in an instant, just keeping an eye on the good ones
