Old 25-09-2009, 10:10 AM   #1 (permalink)
naughty boy :) :)
mahesh's Avatar
Default Good Case Fan in the range 400-450 bucks?
hi all,
one of my colleague is going to delhi tomorrow.
i would like to buy a good case fan from there.
which fan should i buy and from where in delhi?
also plz tell me the exact prize. my rig is in my siggy.
thanks.
Phenom II 550 BE | GA-MA78GM-US2H | 160 gb + 500 gb hdd | 2 X 2 gb XMS2 | HD 4850 1 GB | 2033 SW | Tagan TG600-U37 | CM 690
mahesh is offline
Old 25-09-2009, 10:15 AM   #2 (permalink)
Crowman
Krow's Avatar
Default Re: Good Case Fan in the range 400-450 bucks?
Cooler Master 120mm LED fan 90CFM.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 25-09-2009, 10:18 AM   #3 (permalink)
Super Moderator
asingh's Avatar
1. Nehru Place.
2. Coolermaster 120MM. Approx 450.
asingh is offline
Old 25-09-2009, 10:47 AM   #4 (permalink)
naughty boy :) :)
mahesh's Avatar
^^ Can u specify the model number plz
mahesh is offline
Old 25-09-2009, 10:57 AM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
here:
http://www.coolermaster.com/product.php?product_id=4375
and this is 200mm huge fan: http://www.coolermaster.com/product.php?product_id=6474
desiibond is offline
Old 25-09-2009, 10:58 AM   #6 (permalink)
Super Moderator
asingh's Avatar
R4-L2R-20CK-GP - BLUE
R4-L2R-20CGF-GP - GREEN
R4-L2R-20CR-GP - RED
asingh is offline
Old 25-09-2009, 11:09 AM   #7 (permalink)
naughty boy :) :)
mahesh's Avatar
thank you all.
i will go with one of those 120 mm led fans.
mahesh is offline
Old 26-09-2009, 01:06 AM   #8 (permalink)
AMD - Aaja Meri Darling
I have the CM 120MM Green LED Fan (replaced the front fan that came in the bijli cabby ) It's very quiet and has very good airflow, HDD didn't cross 35*C (when I made new partitions after installing windows)
Current temperature WD 500GB : 28*C (reported by Everest)
AMD Athlon II X4 620 | ASUS M4A785TD-V EVO - 785G
Xeno is offline
Old 26-09-2009, 01:55 AM   #9 (permalink)
Super Moderator
asingh's Avatar
Well I have 5 of the blue ones, and 2 without an LED....................!
4 run off an OEM fan controller, so at nights, there is less light bleed.
asingh is offline
Old 26-09-2009, 08:00 AM   #10 (permalink)
If u hav an cm 690 then here's my suggestion....'
my friend hav a cm 690 and there r 6 fan options in the case..., and one blue led 120mm is already comes with the case..'
He bought cooler master 120 mm fans in bundle pack 4 fans @ 800 bucks and a 80mm slim fan for cpu cooling..'
This is the best for a cm690 and find out is there any dealer of cm there u can get bundle packs like this or else a single fan will cost u 375 bucks...'
There r led fans also available in bundle 4 led 120mm @ 1100 bucks...'
Arnab boss is offline
Old 27-09-2009, 04:56 PM   #11 (permalink)
naughty boy :) :)
mahesh's Avatar
thanx guys. dont know any coller master dealers.
mahesh is offline
Old 27-09-2009, 06:00 PM   #12 (permalink)
But u can check shops If they had any bundle packs 4 fans...'
Old 27-09-2009, 08:53 PM   #13 (permalink)
Super Moderator
asingh's Avatar
Yea..I bet you shops have the bundles, but the owner will sell them unbundled at a higher price.
Indian vendors -- typical.
asingh is offline
Old 28-09-2009, 07:56 AM   #14 (permalink)
The Sorcerer's Avatar
Try and see if you can get delta fans
Hardware BBQ
The Sorcerer is online now
Old 28-09-2009, 01:06 PM   #15 (permalink)
Super Moderator
asingh's Avatar
Are they good, never heard of them..
asingh is offline
Old 28-09-2009, 01:16 PM   #16 (permalink)
Delta fans, I saw a video on youtube about one of those.
loud but the airflow is enough to make the fan float like a hovercraft.
Definitely good
Lynx India has them ..
Xeno is offline
Old 28-09-2009, 05:06 PM   #17 (permalink)
Crowman
Krow's Avatar
^Please link it here (lynx link and the youtube links).
Krow is offline
Old 28-09-2009, 07:36 PM   #18 (permalink)
You get a lot of models. Honestly spending so much for 50 cfm 120mm fans for 450 bucks is just too much. LED is simply becomes a bore eventually.
Hardware BBQ
Old 28-09-2009, 10:28 PM   #19 (permalink)
Crowman
Krow's Avatar
^And CM 120mm LED 90CFM fans are available here for 450 bucks!
Krow is offline
Old 29-09-2009, 03:15 PM   #20 (permalink)
You get 55cfm coolermaster 120mm non led fans for 250-300 bucks here @ lamington. For ball bearing- 400-500 bucks is quiet a lot. Sleeve bearing in that price is pretty decent considering the ripoff factor .
Going around lamington and you will find shops selling genuine NMB oem and delta fans for 200-300 bucks- without the molex connector but that barely an issue for the resourceful people.
Hardware BBQ
Old 29-09-2009, 09:33 PM   #21 (permalink)
Crowman
Krow's Avatar
But does the CFM make a difference to fans? AFAIK, more CFM means better air flow. What do u say?
Krow is offline
Old 30-09-2009, 12:35 AM   #22 (permalink)
Super Moderator
asingh's Avatar
I think it does. CFM = cubic feet per minute. It is a non SI unit to designate the volume of gas/liquid passes a stationary point in on minute.
So higher the CFM for a fan, the more air volume it is clearing.
asingh is offline
Old 30-09-2009, 12:45 AM   #23 (permalink)
Crowman
Krow's Avatar
So a 90 CFM fan is a great buy for 450 bucks and that too with the LED, isn't it?
Krow is offline
Old 30-09-2009, 01:39 AM   #24 (permalink)
trusting that the CFM values printed are actually true ...
Xeno is offline
Old 30-09-2009, 10:06 AM   #25 (permalink)
Super Moderator
asingh's Avatar
If 120mm+LED+Coolermaster = Rs. 450
me =
am satisfied
asingh is offline
Old 30-09-2009, 02:25 PM   #26 (permalink)
^ ditto, it does push the air quite good :O my harddrive remains cool all the time. hasn't crossed 34*C till date
Xeno is offline
Old 30-09-2009, 04:49 PM   #27 (permalink)
Super Moderator
asingh's Avatar
^^ Mine (both) are at 40C always..in the CM690.
Is that high for HDDs...??
asingh is offline
Old 30-09-2009, 05:19 PM   #28 (permalink)
Still cool enough I think. My older IDE disks used to run at 38-44*C with the older case.. although recently one of them crossed 50*C (I assume since one of them ran much hotter than the other) and it died :O
Better to keep em as cool as possible.
(I live in a relatively cold place so room temperatures are like 22-27*C usually)
Xeno is offline
Old 30-09-2009, 08:00 PM   #29 (permalink)
Crowman
Krow's Avatar
My temps are in the range of 36-40 for HDD1 which is 160GB Hitachi and about 38-42 for HDD2, which is 500GB Seagate.
Krow is offline
Old 07-10-2009, 12:29 AM   #30 (permalink)
royal's Avatar
Wink Re: Good Case Fan in the range 400-450 bucks?
CM fans are sort of OK but nowhere near real performance fans like Scythe
royal is offline
- by bhaskar
