Old 25-09-2009, 12:08 AM   #1 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Question Is sumthing wrong with my proccy?
In CPU Usage History graph in performance tab in taskmanager, it shows graph in only one core. And thr is very low graph in the other core.
Like I've monitored and uploaded some images here.....plz take a luk...
http://img121.imageshack.us/img121/777/taskmanager.jpg
http://img225.imageshack.us/img225/5...skmanager2.jpg
http://img225.imageshack.us/img225/6...skmanager3.jpg
Is thr sumthing wrong with my proccy?? What happend to the other core??
I checkd affinity.....its set to both the cores. Then y the other core is not performing like the 1st one??
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now
Old 25-09-2009, 06:27 PM   #2 (permalink)
Simply a DIGITian
Default Re: Is sumthing wrong with my proccy?
Hey friends plz help me out.....
Old 25-09-2009, 07:24 PM   #3 (permalink)
Crowman
Krow's Avatar
Try running Prime95 or wPrime or SuperPI. These apps will stress your CPU to full load, i.e., 100% usage. Then post screenies.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 25-09-2009, 08:24 PM   #4 (permalink)
Simply a DIGITian
okz......thnx.....
Old 25-09-2009, 08:38 PM   #5 (permalink)
Simply a DIGITian
Ya...its perfectly f9. All the 3 sw utilized my both the core to 100%
Old 25-09-2009, 10:09 PM   #6 (permalink)
Crowman
Krow's Avatar
The problem is not in proc, but most apps are built keeping only one core in mind and hence the problem you saw. You can also try one more thing.
However you attained the 50% CPU usage, use the same method first to attain 50% usage.
Now run task manager. right click on the process (which is using 50%) and click on set affinity and set to Core #1 (uncheck core #0).
Run the same prog again(dont close the first) and set affinity to core #0 and uncheck core #1.
Never tried it, but since you seem to have a bit of free time anyway, can you try this? It's just which core an app can use.
Krow is offline
Old 25-09-2009, 10:58 PM   #7 (permalink)
Simply a DIGITian
Hehehehhehhe......nice trick....!!
- by bhaskar
