Alright, I just happened to view my system properties and I saw
And Also in ASUS's PC Probe under WMI
But Everest Ultimate Edition shows:-
Now why do both Windows and Asus Pc Probe show the cores (all four of them) to be running at 783 Mhz ?
While Everest reports all of them running at 2.6Ghz ? Why the odd number "783" ? I Can't quite understand how the value went below the Ghz mark even.
I quite don't care for the number since its anyway much faster than my older system but I'd want to know if its
really running at only 783 Mhz.
Config
OS: Windows XP SP2 (32 Bit)
Proccy : AMD Athlon II X4 620 (2.6 Ghz)
Motherboard : ASUS M4A785TD-
V EVO
In BIOS:
Cool'n'Quiet = Enabled
C1E (Enhanced Halt State) = Enabled
^ could it be due to these features enabled to save power ?
Vcore : 1.10 - 1.18V
CPU Temp: 32-35*C
