Old 21-09-2009, 04:05 PM   #1 (permalink)
I'm in 3D Grafix world!!!
Nithu's Avatar
Unhappy Best CPU Cooler under 2K
Guys pls help me...
My Q8200 reaches 59*c on idle and 74*c on load.....
Can you suggest me best CPU cooler with good performance under Rs. 2000/-....
I have one more question, does the CPU cooler comes with cooling fan and thermal paste??...or purchase separately??....
Thnx in advance....
Intel Q8200 | Gigabyte G41M-Combo | Sapphire Radeon HD 5670 512MB | Transcend 2 x 2GB DDR2 800 | WD 1TB | CoolerMaster Hyper TX3 |
ASUS X53SC-SX536D
Nithu is offline
Old 21-09-2009, 05:26 PM   #2 (permalink)
Crowman
Krow's Avatar
Default Re: Best CPU Cooler under 2K
Under 2k, a good cooler is difficult to find seriously. Good coolers would be CoolerMaster Hyper 212 @ 2.2k and Sunbeamtech Core Contact Freezer @ 2.4k. Some coolers come with one fan but no cooler comes with thermal paste AFAIK.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 21-09-2009, 05:36 PM   #3 (permalink)
Nithu's Avatar
^^ thanx for your suggestion.....but using the above coolers how much Degree it'll reduce??...is it worth buying low cost cooler?...
ASUS X53SC-SX536D
Nithu is offline
Old 21-09-2009, 05:43 PM   #4 (permalink)
Crowman
Krow's Avatar
^Both the above coolers are great. I really dont know about Q8200, but on the E7400 used by asigh, he could OC till 4GHz and be on 70 degs at full load with the Hyper 212 and even topgear reduced temps from 80 to 40 with the Hyper 212 on E5200.
Krow is offline
Old 21-09-2009, 06:31 PM   #5 (permalink)
Nithu's Avatar
^^ that's nice....i don't wanna OC. I'm thinking about buying Cooler Master Hyper 212. Its comes with fan right?
ASUS X53SC-SX536D
Nithu is offline
Old 22-09-2009, 11:02 AM   #6 (permalink)
Super Moderator
asingh's Avatar
yes, the Hyper 212 is a good cooler. Is bolt-attachment type, so the contacts are firm. It comes with one fan default, (pull), a second can be easily mounted. It uses 120MM standard Coolermaster fans. As above mentioned, I am able to OC to 4.00 Ghz.
Suggestion:
Use the back plate attachment to mount the cooler. It can be mounted without it. But it is better to use the back plate, will prevent bowing of the motherboard, since the cooler weighs quite a bit.
You will get a tube of Coolermaster TIM along with it. Use that, clean the contact surfaces with isopropyl alcohol prior to placing the TIM.
asingh is offline
Old 22-09-2009, 01:18 PM   #7 (permalink)
Crowman
Krow's Avatar
^Nice suggestion asigh. Many people don't notice until one year at least that their mobos are bent.
Krow is offline
Old 22-09-2009, 01:56 PM   #8 (permalink)
The Sorcerer's Avatar
Tsk tsk. If one can spend, doesn't mean one HAS to spend. If one spends, one must know what to spend for and for one to spend, one must know the reason
The reason?
Just change the TIM on the OEM cooler rather than wasting 2k for a cooler especially if your intention is not to overclock. However there are many reasons for a bad temps. If the motherboard temps are fine on load but the cpu temp readings- there are many reasons. It either might require new bios or the thermal sensors aren't soldiered properly. If the complete system's temps are bad, then there some reasons. Substandard psu does stress the system and thereby generating heat. The case doesn't have airflow. If enough air is not pushing in and out, how can one expect it to be cool?
Start from here:
Flash to a new bios, use real temp and let us know the reported temps. Do some cable management. What kind of fans do you have have 80mm or 120mm? and what's the cfm? Room temps?
Hardware BBQ
Last edited by The Sorcerer; 22-09-2009 at 01:58 PM. Reason: Automerged Doublepost
The Sorcerer is online now
Old 22-09-2009, 07:26 PM   #9 (permalink)
Nithu's Avatar
^^ Is Coolermasters TIM good? Do I need to go for Arctic Silver 5??....
Originally Posted by The Sorcerer View Post
Start from here:
I had done flashing BIOS....but I’m getting same core temps....like 59*c on idle and 73/74*c on load...
Ya I’m using Real temp 3.0.....I’m using 80mm rear fan...I think room temp is 28*c - 31*c....
ASUS X53SC-SX536D
Nithu is offline
Old 22-09-2009, 08:26 PM   #10 (permalink)
^^ What's the tj max on the core temp? What about the board? Which psu? Did you read my previous comments?
Hardware BBQ
Old 22-09-2009, 08:26 PM   #11 (permalink)
Super Moderator
asingh's Avatar
Yea..Coolermaster TIM is fine.
Remount the HSF with good TIM, and check
asingh is offline
Old 22-09-2009, 08:46 PM   #12 (permalink)
Nithu's Avatar
Ya, i read your previous comments....
Distance to TJ Max is 42,44,43,44.....(what is tj max? whats the use? im a noob.)..
PSU - Zebronics 500W
How to know MB tems??...any soft?...
ASUS X53SC-SX536D
Nithu is offline
Old 22-09-2009, 09:38 PM   #13 (permalink)
Super Moderator
asingh's Avatar
TJmax is the thermal junction max. It is the maximum temperature, at which the CPU will start to throttle (run less cycles ...process slowler), to protect itself from burning out. Post this, it will cease to function..and you get a computer HANG...or Blue Screen of Death. (BSOD). This is a Intel specification, and is different for each chip.
So if one says TJmax = 15C. It means, if your CPU gets 15C hotter, the above will start. This is not that accurate, I have posted some stuff related to this in the OC thread. Only when th temperatures are high...it is correct.
You can get started here and here...for hardware terms.
asingh is offline
Old 23-09-2009, 08:07 AM   #14 (permalink)
Nithu's Avatar
Thanks man.....thanks for the information....
I'm getting BSOD whenever i play games / doing 3d intensive work........
I think this happens when core temp reaches above 75*c....
ASUS X53SC-SX536D
Nithu is offline
Old 23-09-2009, 08:15 AM   #15 (permalink)
# Use HWmonitor to know complete temps and voltages on the rails. Do put the screenshot over here.
# Changing the psu is recommended: Basic guide for the right power supply
# Another possibility exists, assuming the motherboard temps and cpu temps have more than 10-15 degrees difference on load (always disregard idle temps) that the thermal sensors arent reading the temps properly. To make sure the thermal sensors are calibrated properly, read this and follow the complete procedure:http://www.techpowerup.com/realtemp/docs.php
# Do note that doing all this is vital, if your processor has trouble getting proper temps, changing the hsf might be futile, as you will still get inaccurate readings.
Hardware BBQ
Old 24-09-2009, 01:44 PM   #16 (permalink)
maverick786us's Avatar
I think you can get Arctic Cooling Freezer 7 Pro for less than 2k it has got a fan onboard, so you don't need to purchase a separate fan. Its not as good as Thermal Right Ultra Extreme but still solve your purpose if you are not heavily Over Clocking it. TRUE does'nt come up with a cooling fan, you need to purchase an 120 MM Fan. However with TRUE you don't even need a fan. Its just that a fan fixed in TRUE can make the CPU even cooler, and yes TRUE comes with thermal paste
(Gaming Rig) Intel E8400 @ 3.6Ghz, ASUS P5Q Pro, 4GB G.Skill DDR2 800, WD 6400AAKS HDD, MSI Cyclone GTX 460, Corsair 650TX, CM 690, Dell SP2208WFP (22 inch), Windows 7 Ultimatum 64
maverick786us is offline
Old 24-09-2009, 04:38 PM   #17 (permalink)
Super Moderator
asingh's Avatar
Please provide the following:
1. Your vCore settting from BIOS.
2. Screen shot of a RealTemp run.
3. CPU-Z Screen shot. (First tab)
lets start at the root. We all are recommending -- to hay wire.
asingh is offline
Old 24-09-2009, 07:54 PM   #18 (permalink)
Nithu's Avatar
@The Sorcerer,
This is what i got using HWmonitor.
ASUS X53SC-SX536D
Nithu is offline
Old 24-09-2009, 08:29 PM   #19 (permalink)
Nithu's Avatar
1. BIOS readings are like this......
Current CPU Temperature : 33*C / 91*F
SYS Fan Speed : 0 RPM
CPU Fan Speed : 2481 RPM
MCP Fan Speed : 0 RPM
CPU VCore : 1.13v
VDDR Voltage : 1.87v
+1.2v Voltage : 1.22v
+5v Voltage : 4.92v
+12v Voltage : 11.72v
VCC : 5.07v
BAT Voltage : 3.07v
5vSB Voltage : 5.10v
2. Real Temp.
CPU Cool Down Test
3. CPU-Z
ASUS X53SC-SX536D
Nithu is offline
Old 24-09-2009, 10:20 PM   #20 (permalink)
Super Moderator
asingh's Avatar
The CPU is running hot..but not as HOT that you get BSOD while gaming.
Are you using the latest nVidia drivers for your GPU.
Did you reseat your CPU HSF as The Sorcerer recommended..?
asingh is offline
Old 25-09-2009, 04:51 AM   #21 (permalink)
Nithu's Avatar
^ Yes, I'm using the latest nVidia drivers.
No. I didn't reseat my CPU HSF.
ASUS X53SC-SX536D
Nithu is offline
Old 25-09-2009, 08:20 AM   #22 (permalink)
Super Moderator
asingh's Avatar
Then please do.
1. Use a good TIM
2. Clean both contact surfaces with isopropyl alcohol
3. Clean the HSF -- removing all dust residue.
asingh is offline
Old 25-09-2009, 06:13 PM   #23 (permalink)
Nithu's Avatar
Then please do.
1. Use a good TIM
OK, I'll do that.
So i don't need to buy new CPU Cooler?..
ASUS X53SC-SX536D
Nithu is offline
Old 25-09-2009, 07:12 PM   #24 (permalink)
Crowman
Krow's Avatar
Not if you are not interested in OCing.
Krow is offline
Old 25-09-2009, 07:23 PM   #25 (permalink)
Nithu's Avatar
^^ I'm not interested in OCing.....So Intel stock cooler OK?
ASUS X53SC-SX536D
Nithu is offline
Old 25-09-2009, 07:27 PM   #26 (permalink)
Crowman
Krow's Avatar
Personally, I do not like it. But if you do the above mentioned things and your temps are fine, then its good as it is doing the job. Else, you may just have to buy the cooler.
Krow is offline
Old 25-09-2009, 08:50 PM   #27 (permalink)
Super Moderator
asingh's Avatar
First reseat your stock HSF as the procedure mentioned...and tell us the temperatures.
Then we can suggest. Personally I also do not like them -- but I OC.
asingh is offline
Old 25-09-2009, 08:58 PM   #28 (permalink)
Nithu's Avatar
@Techalomaniac, @asigh and @ALL..
Thanx guys......
Now i don't have TIM....But when i get one I'll post ma temps...
ASUS X53SC-SX536D
Nithu is offline
Old 28-09-2009, 08:06 AM   #29 (permalink)
The Boss
aytus's Avatar
Hi, can we know if those temps are idle temps or temps after load? 80 degree on load is not something i,d be comfortable with. And afaik throttling starts much before tjmax ,, not too sure bout that tho.
And as for the suggestion for a aftermarket hsf . i think you should go with the Cooler master HYPER 212 PLUS its a newer ver. of hyper 212 and suits ur budget at around 1800 rupees...
G3N10U5 BY B1RTH, HACK3R BY CH01C3
E5200; Biostar P43-A7; Palit GF 9600GT; Corsair 4GB; CM extreme power 390W
aytus is offline
Old 28-09-2009, 01:36 PM   #30 (permalink)
Super Moderator
asingh's Avatar
You can know the temperatures, because the stressing application tells so, if its putting load or idling the CPU. (Example RealTemp+Prime95)
It is a standard specificiation -- throttling to start at TjMax. What is the definition of 'much before'. If throttling would start 'much' before Tjmax then most Intel CPUs would be throttling more than spinning at the highest frequencies...!
Hyper 212 Plus:
I had the choice to buy this too, but did not go for it. It has a basic design flaw. The copper pipes are made to make direct contact with the CPU. But due to this, there are gaps in the overall surface. So the overall HSF surface is not in contact with the CPU block. Though that area can be filled with TIM.
Though apart from this small trivial matter, this is a good HSF for the money.
asingh is offline
- by bhaskar
