Old 19-09-2009, 10:58 PM   #1 (permalink)
sona's Avatar
Default Fan for Zebronics Bijli cabinet
I have got a Zebronics bijli cabinet but it doesn't have proper ventilation facility.
I want to install a rear fan for the cabinet but a 120mm fan doesn't work for me as the space provided is too less for a 120 mm fan. Also it is large for a 80mm fan.
Can anyone tell me the proper fan size for the rear side????
adn
sona is offline
Old 19-09-2009, 11:29 PM   #2 (permalink)
Crowman
Krow's Avatar
Default Re: Fan for Zebronics Bijli cabinet
90mm??? Ask topgear... he also uses your cabby!
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 20-09-2009, 05:34 AM   #3 (permalink)
Fast 'N' Furious
topgear's Avatar
Zebronics Bijli cabby has enough space to fit a 120mm rear fan as I'm using a CM 120mm fan with that cabby - so you can count on that
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 20-09-2009, 01:25 PM   #4 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
i think in the newer sets they have decreased the fan size because imo it DOES not fit 120mm fans , i have same cabby Btw
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 20-09-2009, 01:51 PM   #5 (permalink)
Crowman
Krow's Avatar
@OP go for a 90mm fan of the highest CFM you can find in case 120mm doesn't fit ur cabby.
Krow is offline
Old 20-09-2009, 02:17 PM   #6 (permalink)
The Sorcerer's Avatar
Exclamation Re: Fan for Zebronics Bijli cabinet
See if you can get delta fans with 50+ cfm. You get 120mm coolermaster fans which cost 250 bucks odd.
Hardware BBQ
The Sorcerer is online now
Old 21-09-2009, 05:03 AM   #7 (permalink)
Fast 'N' Furious
topgear's Avatar
That very odd. I have bought 4 of'em so far. All of them supports 120mm fan at the back
BTW, if it does not fits 120mm fan then the only option is to go for 80mm fans. They can be bagged for as low as Rs. 40
topgear is offline
- by bhaskar
