Old 19-09-2009, 07:54 PM   #1 (permalink)
Default Help needed selecting mother board
Hi,
Need to take a new mother board to replace an Intel D945 GCNL. Need to select mother board such that it can work with existing components.
Can you please suggest some mother boards and what factors to be looked into?
and also should I go for Intel or Gigabyte or any other brand(in terms of service)?
ckanth99 is offline
Old 19-09-2009, 08:19 PM   #2 (permalink)
Crowman
Krow's Avatar
Default Re: Help needed selecting mother board
Gigabyte G31-ES2L if ur RAM is DDR2! Intel boards are crap.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 24-09-2009, 12:32 PM   #3 (permalink)
Thank you Techalomaniac.
Should I look for any other factors? For eg, This mother board's description contains that it supports DDR2 at 1066 speed. But, i have DDR2 RAM with speed of 667.
Would I be able to use this RAM if I buy above M/B?
And also would this M/B supports Pentium Dual Core processors? how to find out this information?
ckanth99 is offline
Old 24-09-2009, 01:42 PM   #4 (permalink)
What's your budget for the motherboard. The one mentioned by Techalomanic is very good and is cheap too.
hell_storm2006 is offline
Old 24-09-2009, 01:55 PM   #5 (permalink)
Crowman
Krow's Avatar
Yes you can run 667MHz DDR2 RAM in your rig without probs.
It supports Pentium Dual Cores AFAIK. For more info, check out gigabyte's website.
http://www.gigabyte.com.tw/Support/M...3134#anchor_os
Krow is offline
Old 24-09-2009, 02:52 PM   #6 (permalink)
Thank you Techalomanic. I will check other details.
ckanth99 is offline
- by bhaskar
