Old 16-09-2009, 12:37 AM   #1 (permalink)
jit_devil2's Avatar
Default powering the monitor directly
hey i have a 400watt local psu with a 15" crt monitor......the monitor gets its power directly from the psu which has 2 3 pin sockets..one for the monitor and the other for the powercable.i was wondering if its possible to buy a powercable and let the monitor get its power directly from the switchboard...................it should take some load off my psu....is it ok to do that????
jit_devil2 is offline
Old 16-09-2009, 03:37 AM   #2 (permalink)
Default Re: powering the monitor directly
It's OK, no harm in doing that. But there's no need either. Your monitor does not actually receive power from the PSU's electronic circuits.
The power outlet for the monitor is connected directly to the mains AC input inside the PSU box. It does not present any extra load on the PSU circuits. The monitor power outlet is put there simply for convenience.
This is how it is wired inside the PSU:
pimpom is offline
Old 16-09-2009, 04:29 AM   #3 (permalink)
IronMan; Ready to Roll...
IronManForever's Avatar
^ Yeah, right.
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
IronManForever is offline
Old 16-09-2009, 08:51 AM   #4 (permalink)
jit_devil2's Avatar
thnx
dat was imformative
- by bhaskar
