I have a ADSL line and have been networked it in connecting two PCs using a switch. The problem is whenever two PCs are used simultaneously connection becomes slow in one pc.
When the other Pc is switched Off it becomes normal. Is there any way that i can control the flow of bandwidth to the other PC or any any other solution so that the bandwidth is equally shared.
Configure NAT sessions in Router..
Posted again:
Configure NAT Sessions in Router.. Allot the (max sessions/2) to each user..
Reason: Automerged Doublepost
