| Forum |
#1 (permalink) |
I'm looking out to buy a budget PC. I've chosen the X2 250 processor. I need a good motherboard for this. Preferrably under 4K. It seems there's a 785G chipset mobo from Biostar at 3.5K(Price Lynix-india). Is it good? or shall I look for some other board? Any help would be much appreciated! Does AM2+ motherboards support my processor? In the supported CPU list of mobo if the Athlon X2 processor is included, but the socket is not AM3 - what does that mean? Does that mean there are X2 processors out there with AM2+ socket? Anyway here's some of the shortlisted Models Biostar A785GE Rs. 3240 Biostar TA785GE 128M Rs. 4156 Asus M4A78-EM Rs. 4725
Intel D930&945GNTL| 2x1GB 667 Mhz(Transcend+Kingston)| 500GBSeagate+200 GB WD|Zotac 9600GT Amp!| Zebronics Platinum 400W|Dell SP2208WFP|Logitech z5500| Lite-onDVD-RW+LGDVD-R Last edited by emmarbee; 07-09-2009 at 10:36 PM. |
#2 (permalink) |
Crowman
Try looking for Gigabyte based boards. They have better build quality AFAIK. Biostar boards are pretty good too.
Like a post? Use the reputation button.
Abusive, offtopic post? Use the report post button. Read before messaging any moderator for any query: FAQ + answers for new members Read all the sticky threads before asking any type of query. Most basic questions are answered in those. |
#3 (permalink) |
Crowman
X2 250 is AM3 right? AM3 is backward compatible with the AM2+ socket, but AM2+ CPU is not compatible with AM3 socket.
#6 (permalink) |
Thanks for the suggestions guys. But isn't there any other solution from gigabyte or asus at the same price range(4K)?
@Techalomaniac - thanks for the info. SO I guess I can buy the AM2+ socket boards too.
Intel D930&945GNTL| 2x1GB 667 Mhz(Transcend+Kingston)| 500GBSeagate+200 GB WD|Zotac 9600GT Amp!| Zebronics Platinum 400W|Dell SP2208WFP|Logitech z5500| Lite-onDVD-RW+LGDVD-R |
#8 (permalink) | |
Crowman
^Really? I thought they do. I mean u need a BIOS flash, but they do support the AM3 CPU...
Here you go... Quote:
@ emmarbee Biostar boards are good, but please look for Gigabyte 785 boards too. You can buy the Biostar ones as they are pretty good.
#9 (permalink) | |
Bond, Desi Bond!
dude. it's the other way around. AM3 processor can fit in AM2+ and AM3 sockets. AM2+ processor cannot fit in AM3 socket There are many who are using AM3 processors in AM2+ boards. Check this link for my AM2+ motherboard processor support list. http://www.gigabyte.com.tw/Support/M...2995#anchor_os it support all AM3 processors. now, check this AM3 785G board: http://www.gigabyte.com.tw/Support/M...3156#anchor_os it only supports AM3 processors. moreover, Biostar A785GE is AM2+ board that also supports AM3 and takes DDR2 RAM. I would pick MSI's entry level AM3 board over this as AM3+DDR3 does give performance boost for AM3 processors.
My first blogspace: http://desiibond.blogspot.com |
#11 (permalink) |
Crowman
^785G is a chipset and not a mobo.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
