Old 06-09-2009, 08:28 PM   #1 (permalink)
Crowman
Krow's Avatar
Default CPU Cooler for AMD Phenom II X4 940
I own an AMD Phenom II X4 940 and I need a CPU cooler for it.
Consider the following factors :
- I intend to do some serious video editing, for a movie of half an hour or so in length.
- We have about 22GB of footage.
- Budget is 3.5k max but i would rather spend less and get a more VFM cooler for it.
- I will OC later.
- My cabinet is CM-Elite 334
I want to have the most bang for buck cooler at with great performance.
Config :
Phenom II X4 940 @ 3GHz
GA-MA790GP-UD4H
2x2GB Kingston DDR2 800MHz [Adding 2x2GB OCZ Titanium 800MHz]
CM-Elite 334
Corsair VX450W
Onboard GFX - HD3300 128MB+512MB shared VRAM
160GB + 500GB HDD's
Like a post? Use the reputation button.
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 06-09-2009, 09:55 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: CPU Cooler for AMD Phenom II X4 940
3k bucks: http://www.thermalright.com/new_a_pa...50aHVzaWFzdA==
2.5k bucks: http://www.ocztechnology.com/product...a_2_cpu_cooler
desiibond is offline
Old 06-09-2009, 10:07 PM   #3 (permalink)
Crowman
Krow's Avatar
Thanks for the links desii. Does the Vendetta 2 come with the fan? Is the TRUE 120 eXtreme worth the extra .5k?
Krow is offline
Old 07-09-2009, 05:23 AM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
You can try Sunbeamtech core contact freezer 120mm or this OCZ vendetta 2 which is also good. Both of them use heatpipe-direct-touch
Acc to many sites SBCCF 120mm is slightly more better as compared with vendetta 2.
But TRUE 120mm is the best choice ie air cooler for AMD procs So it's worth spending around 4K for this one.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 07-09-2009, 06:11 AM   #5 (permalink)
BSD init pwns System V
hellknight's Avatar
OCZ Vendetta was able to cool Intel Core 2 Quad QX9650 to 50 Degrees only when it was running at 4 GHz and on full load.. just get it dude.. its awesome..
My blog :- www.openenclave.wordpress.com
hellknight is online now
Old 07-09-2009, 07:03 AM   #6 (permalink)
Crowman
Krow's Avatar
Thanks for continued support. I am inclined for the TRUE 120 (non-black edition) as it is available for 3k. I'll get a quote on it and reply soon. I'm getting the OCZ RAM's for sure.
Meanwhile: damngoodman999 where are you? Please join this discussion.
Posted again:
OCZ Vendetta is also on my shortlist along with SCCF. I'll check out reviews. Can someone please post a comparitive review of CPU coolers? Someone had posted it on anoter thread. It was a test of 25 CPU coolers I think...
That might gimme an idea. But I'm willing to spend a lil' extra for a decrease in temp as I need my CPU to run as cool as possible...
Krow is offline
Old 07-09-2009, 08:22 AM   #7 (permalink)
Bond, Desi Bond!
desiibond's Avatar
btw, There is one more cooler "Megahalem". This one costs around 4k I think and beats Vendetta 2 easily and with a bettter fan, it cools down Nehalem to 22-23 degrees.
1) Prolimatech Megahalem
2) OCZ Vendetta 2
3) Thermalright TRUE 120 for LGA1366
4) Sunbeam Core contact freezer
that would be the priority order for me to search for.
Megahalem: http://benchmarkreviews.com/index.ph...&limitstart=15
Old 07-09-2009, 09:57 AM   #8 (permalink)
damnbadman666
damngoodman999's Avatar
Sorry dude , i dint saw yet - finally u came to purchase CPU cooler gr8 . good luck on ur purchase
Go for Desi , Hell & topgear suggestion according the TRUE 120 & megahalems
My pick would be megahalems over TRUE 120
Before that check ur cabinet these 2 super coolers are big to close side panel ??
Then if u r going for megahalems find if u get AMD bracket for it !
AMD Phenom 2 940 @ 3.4Ghz [Hyper 212+] MA790GP-UD4H OCZ DDR2 2x2GB Asus GTX 560ti 1TB SATA2 LG 20" LED Razer DA mice RED HOT cabby
damngoodman999 is offline
Old 07-09-2009, 10:21 AM   #9 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
OCZ vendatta is a good buy. That's a good choice, yes.
http://pleaseguide.me/
comp@ddict is online now
Old 07-09-2009, 10:23 AM   #10 (permalink)
Bond, Desi Bond!
desiibond's Avatar
damn it. Totally forgot that it's for AMD. Thanks damngoodman999 for reminding about that.
yes. megahalem is for LGA1366 and LGA775 and won't fit on AMD mobos. The next pick would be OCZ vendetta 2
I would pick this over the rest coz OCZ has good reach in Indian market compared to sunbeamtech or thermalright. And it does outperform TRUE 120.
Posted again:
also, since it costs 500 rupees less than TRUE 120, you can replace the stock cooler on vendetta 2 with a high performance fan like this 90CFM/19decibel (81CFM max and 20-32 decibel for stock fan) fan: http://in.coolermaster.com/products/...e=2272&id=6046
which is available for 550 bucks.
Old 07-09-2009, 10:30 AM   #11 (permalink)
damnbadman666
OCZ vendetta 2 just the job done & TRUE 120 is always ahead , the difference u find would be 2-4 degree TRUE 120 is lesser , if u find BUDGET then Go for OCZ vendetta 2 thats cool buy !
Old 07-09-2009, 10:36 AM   #12 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Yup, give the extra 500 bucks to a mandir or so(bhagwan tera bhala karega). ^_^
Old 07-09-2009, 10:39 AM   #13 (permalink)
damnbadman666
500 bucks to temple ?? , Bhagwan tho cooling karega ??
Old 07-09-2009, 11:01 AM   #14 (permalink)
darklord's Avatar
TRUE, nothing comes close to it.
darklord is offline
Old 07-09-2009, 11:30 AM   #15 (permalink)
hellknight's Avatar
and don't forget to make an overclocking profile (if your BIOS supports that).. to overclock the CPU automatically to the highest stable score that you will reach.. otherwise.. the stock cooler is fine if you don't wanna overclock..
btw.. i'm also thinking of getting a cooler for my AMD Phenom II 720 BE..
Old 07-09-2009, 03:14 PM   #16 (permalink)
Crowman
Krow's Avatar
Thanks for arriving here finally. Maybe trains from the south were late. But I was waiting for u especially as you are Phenom IIer like me...
You make sense. The 500 bucks will be well invested on a High performance fan rather than just the cooler.
Budget, I thought Vendetta 2 was cheaper... As I said, I have a budget of 3.5k.
I am giving it to CM High Performance Fan Mandir mostly. (CM (not cief minister) mera bhala karega).
I take your word as you are THE OC man in the forum. However, is it worth the extra 500 bucks + 1000 bucks for push+pull?
More about the OC profile later. I will definitely take advice from a lot of places b4 I start OCing.
Krow is offline
Old 07-09-2009, 03:51 PM   #17 (permalink)
Crowman
Krow's Avatar
UPDATE: Quotes for Coolers.
OCZ Vendetta 2 = 2.6k
Thermalright Ultra eXtreme 120 Black Edition = 3.5k
Krow is offline
Old 07-09-2009, 06:05 PM   #18 (permalink)
darklord's Avatar
Although the prices have gone up it is still a pretty god damn good cooler. You cant go wrong with it.
darklord is offline
Old 07-09-2009, 07:05 PM   #19 (permalink)
Crowman
Krow's Avatar
Yeah I take your word for that. But I have to look at the budget too. One more query. If I buy say X CPU Cooler, will I get all the supported CPU Brackets for it? Or if I upgrade in the future, then I might have to buy the brackets maybe?
ADDED : OCZ 2x2GB 800MHz DDR2 CL4 Titanium RAM ordered. Should be receiving it by tonight! (Rs.2x1650 + Rs. 50 Shipping) = Rs. 3350.
Investing about the same in the Cooler.
Krow is offline
Old 07-09-2009, 08:47 PM   #20 (permalink)
damnbadman666
Hey Tech
i wana ask some question before deciding CPU cooler ?
Which cabinet are u using ??
Up to how much speed u gona OC ??
Also consider COOLER MASTER HYPER 212 which really good , get which is available with 2 FANS its is also equals the performance of OCZ vendetta 2 ! same like TRUE 120 only 2-4 degree less
CM HYPER 212 - 2.3K 2fans one => 2.5K (worth the money)
Old 07-09-2009, 10:13 PM   #21 (permalink)
Crowman
Krow's Avatar
Cooler Master Elite 334 cabby.
The primary issue is not OCing as I said in my first post. Its serious video editing.
I have 8 GB RAM now. Gonna install Win7 x64 RC and Premiere Pro x64.
I need my CPU to be very cool over long periods of time. I don't mind keeping my cabinet side open.
Basically I want an excellent cooler for editing now and OCing later. I confess I'm total noober in OCing, but this forum has quite a few advisers and also ppl like u and darklord, all can help me oc to max possible, like 3.6-3.8 purely for benchmarks. Then I'll be back to around 3.4 and make it a Phenom II X4 965. I am gonna invest only once, plus I am not gonna be buying a GFX card for a long time now. So I can invest some money (abt 3.5k) in this.
Krow is offline
Old 07-09-2009, 11:06 PM   #22 (permalink)
damnbadman666
Ok get the True 120 silver 2.7K + One good 120mm fan @ 2200 RPM thats enough
will cover 3.5K max , thats truly good for OCing & ur purpose dont confuse by comparing & googling - TRUE120 is really good one faster heater transfer
2.7K truly worth !
Ask Desibond that Cooler master 120MM Fan will fit with True 120 or not , i never checked ?? if it fits means good CM 120 fans are available @ Rs 550
Old 07-09-2009, 11:11 PM   #23 (permalink)
Crowman
Krow's Avatar
When I bought my PC, I got a CM blue led 90cfm 120mm fan for Rs. 450. Could it be the one u r talking about?
Krow is offline
Old 07-09-2009, 11:11 PM   #24 (permalink)
darklord's Avatar
Why wouldnt the CM fan fit if its 120mm ???
As long as its 120mm, any god damn fan will fit. The OCZ Vendetta 2 is a decent cooler, should suffice your need
darklord is offline
Old 07-09-2009, 11:14 PM   #25 (permalink)
Crowman
Krow's Avatar
But the price difference is only 100 bucks, when compared to TRUE 120 silver... If true is better by 3-4 degrees, then it will still be worth it, won't it?
Krow is offline
Old 07-09-2009, 11:30 PM   #26 (permalink)
damnbadman666
If u already have 120MM fan then go for TRUE 120 , good luck sure worth it !
Old 08-09-2009, 02:44 AM   #27 (permalink)
OCZ vendetta 2 fr 2.6k real vfm.
Xigmatek Thor's hammer 3.5k odd.
heavyarms is offline
Old 08-09-2009, 07:11 AM   #28 (permalink)
Bond, Desi Bond!
desiibond's Avatar
if price difference between TRUE120 and vendetta 2 is 100 bucks, go for TRUE 120.
Old 08-09-2009, 08:18 AM   #29 (permalink)
Crowman
Krow's Avatar
Thumbs up Re: CPU Cooler for AMD Phenom II X4 940
But the fan is for HDD's. I think I'll ask some relative to gift me a 120mm fan for diwali.
TRUE 120 silver @ 2.7k, but not in stock. I'll ask ITWares to get it for me.
TRUE 120 black @ 3.5k, in stock.
Final decision :
If TRUE 120 silver is available, I'll get it. Else, OCZ Vendetta 2 is the way to go, along with a fan or two of course.
Thanks to all those who replied for your support. If you still have some comments, feel free to post as I am not going to purchase before 16th September.
Krow is offline
Old 08-09-2009, 08:26 AM   #30 (permalink)
damnbadman666
Wat to say ?? u finalized u ll get TRUE silver 120 with sep16 in STOCK ! then u ll buy
Wat comment post ?? ok i have an idea
How r u ! how is work ?? LOL
How abt getting table fan , IMO it is best system cooler ! place it in the side of u cabinet opened u ll get better cooling
