Old 08-09-2009, 08:30 AM   #31 (permalink)
Crowman
Krow's Avatar
Default Re: CPU Cooler for AMD Phenom II X4 940
^Good idea that about table fan...
I am waiting for that purpose only. I'll give him about 10 days and also keeping a bit busy for the next 10 days. So, after 16th I'll hunt down a TRUE. If not I'll get Vendetta 2.
LOL about the hw r u... hehe!
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 09-09-2009, 04:44 AM   #32 (permalink)
Fast 'N' Furious
topgear's Avatar
Make sure TRUE fits inside your cabby with side panel closed as I had difficulties with Hyper 212 inside bijli cabby though I managed to cut a hole on the side panel with the help of my elder bro
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 09-09-2009, 07:35 AM   #33 (permalink)
damnbadman666
damngoodman999's Avatar
Ya thats wat i told him first ! TRUE is bigger than HYPER212
Hey Tech ! also always keeping opened cabinet is not good , consider this !
damngoodman999 is offline
Old 09-09-2009, 09:31 AM   #34 (permalink)
Crowman
Krow's Avatar
TRUE 120 = L63.44 x W132 x H160.5 mm (heatsink only)
Vendetta 2 = (W)120 x (D)50 x (H)159mm (heatsink)
After rough scale measurements, I think both are going to overshoot the limit a bit.
damngoodman999 - why is it bad to keep the cabby open. Mine is almost always open...
Krow is offline
Old 09-09-2009, 09:47 AM   #35 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^dust.
a closed cabinet with a side fan is much better than open cabinet, unless you put a table fan next to open cabinet
desiibond is offline
Old 09-09-2009, 09:49 AM   #36 (permalink)
Crowman
Krow's Avatar
Ah-ha... Looks like some case modding is due... Maybe I'll just have to do some panel cutting a-la topgear.
Krow is offline
Old 09-09-2009, 01:50 PM   #37 (permalink)
damnbadman666
Thats i bought ASUS Silent Knight AL ! ZALMAN CNPS 9700 is available in mumbai ?? cause its same performance to vendetta !
I think zalman coolers are not available in india ??cry:
Old 09-09-2009, 06:50 PM   #38 (permalink)
Crowman
Krow's Avatar
Whats ur cabby damngoodman999?
I was checking reviews and I had shortlisted (company wise)
Thermalright
Zalman
OCZ
Sunbeamtech
Xigmatech
I dunno about market reach of Zalman and Xigmatech.
Krow is offline
Old 10-09-2009, 05:26 AM   #39 (permalink)
Fast 'N' Furious
topgear's Avatar
Hyper 212 dimension :
112(W) x 92(D) x 160mm(H). So Hyper 212 falls between vendetta 2 and TRUE 120
So I had to cut a hole in my cabby's side panel. If you have better ventilation inside your cabby then it's always better to keep the side panels closed. It's even helps in reducing the temp ! Last year I was running my rig with side panel opened but from this year ( from jan ) I 'm using my rig with side panel closed.
When I touch my cabby I could feel very little heat but last year it was more hot
topgear is offline
Old 10-09-2009, 08:34 AM   #40 (permalink)
damnbadman666
Thermalright
Zalman
OCZ
Sunbeamtech
Xigmatech
I use zebronics reaper !
i use to open my side panel so that 5deg reduce , but dust is big problem
Old 10-09-2009, 09:01 AM   #41 (permalink)
Crowman
Krow's Avatar
It seems, I'll have to do some case mods in order to have decent cooling. The 90mm coolers are not an option for me. I'll handle the dust. Will clean regularly. Gotta be prepared for some hardwork...
Krow is offline
- by kool
- by ax3
