| Forum |
#1 (permalink) |
1) Sometimes the keyboard doesnt work. 2) After hibernating the machine when i switch it on the mouse doesnt work. 3) For the last few days I am getting a bsod - "Driver_IRQL_Not_Less_Or_Equal" which I understood that it may be the problem with the network interface. Now network is inbuilt. 4) Sometimes the pc hangs without any reason. 5) If I move the cabinet while it is `on` the monitor goes blank and the screen comes only after a long period of break. This was not usual but after i bought a 8600gt second hand after taking advice from here the problem has come. I think its the problem with the pci-e slot in the m/b. Thus i have decided to give this m/b for repair as it is still under warranty and buy a new m/b. Plz suggest me a m/b within 3-4k which will have builtin wifi. I have core2duo 6420 proccy. I am averse to buying another asus m/b if its better than others. Also tell me where is the service centre of asus in kolkata.
The most unkowlegeable person on the http, plz tech me!!! Last edited by techani; 06-09-2009 at 04:19 PM. Reason: Adding a link |
#2 (permalink) |
Bond, Desi Bond!
not sure if you can get a mobo with wifi under 4k. Why not but a G31 motherboard and wifi pci card. mobo should cost around 2.5k-3k and wifi card should cost 1k-1.5k
My first blogspace: http://desiibond.blogspot.com |
#4 (permalink) | |
mera kutch nahi ho sakta
jin files ka koi server nahi hota unka bittorrent hota hai |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
