07-09-2009, 10:35 PM
#31 (permalink)
Intel OCer
Re: Suggest for gaming rig at 75k INR.
My site: collegeclassroom.org
08-09-2009, 07:07 AM
#32 (permalink)
Bond, Desi Bond!
guys, one more problem is that he may need to increase his budget or go for Phenom II instead of i7 if GTX295 is picked. Since this card is 29k, I don't think core i7+GTX295 can fit in that budget.
08-09-2009, 10:11 AM
#33 (permalink)
Super Moderator
Heck...we went over board.
Where is the OP..by the way..???
08-09-2009, 10:17 AM
#34 (permalink)
Bond, Desi Bond!
^^ran away
08-09-2009, 10:25 AM
#35 (permalink)
Super Moderator
What about a bad boy Q9550 with DDR3 motherboard.
08-09-2009, 10:48 AM
#36 (permalink)
The thing is they are still LGA775 whose days are numbered! So better it with AMD or Core i7!
08-09-2009, 06:03 PM
#37 (permalink)
Intel OCer
Wait for core i5....pwns amd, and its abit cheaper
08-09-2009, 09:21 PM
#38 (permalink)
Bond, Desi Bond!
update:
core i5 750 price to be set near to 12k.
entry level P55 boards from ASUS/Gigabyte/MSI and to be launched at 7k price point. you may get Biostar models for lower price.
PS: Don't ask me about avialability.
09-09-2009, 01:38 AM
#39 (permalink)
damnbadman666
The OP never posted for long time !
09-09-2009, 10:17 AM
#40 (permalink)
Super Moderator
Probably out buying the stuff...!
28-01-2010, 10:10 AM
#41 (permalink)
"Official HD 7970 Owner"
Guys, plz chk this also.
Core i7 920 Rs -14.5k O'C @ 3.xx GHz [with Water coolings]
Gigabyte EX58 Extreme - Rs -20k
RAM Corsair 3x2 GB 1600Mhz Rs - 12k
HDD 1TB Seagate/WD Rs - 4.5k
Sapphire ATI 5770 1GB DDR5 Rs - 10k
CM 932 Full Tower Rs - 8.5k
Corsair Water Cooler H Series Rs - 5k
120mm Fans CM (3 nos) Rs - 1.5k
PSU CM 600 Extreme Rs - 3.5k
Dell 2409 HD or Alienware 21.5 Optx Monitor Rs - 16k
Logitech Internet Pro Combo Rs - 750
Logitech X540 5.1 / Creative T6100 Rs - 3k - 6k
Recently i got this from Computer warehouse bangalore, Its working flawlessly & i'm happy coz i've customised each & every part.
This shop has given me a warranty period of 3years onsite, but not sure of this will work or not.
As i mentioned already i've overcloked the CPU & got 3.8GHz with water coolings & all the rig cost me around 90k excluding speakers & tax.
Please contact me, if u need any support on overclockiing of CPU, RAM, GPU etc...
+91-9742101998
28-01-2010, 08:23 PM
#42 (permalink)
thats a bad psu.......for such a good config should have gone 4 corsair or gigabyte at least....coolermaster extreme series is bad.....
In the end he will suffer,in the end we will triumph,in the end "there will be only CHAOS"...
01-02-2010, 09:57 AM
#43 (permalink)
HI MAC555,
Please let me know, whether Corsair 650w, will do the job. As my pc is very new, i can change my psu at the earliest, but till now i've not faced any problems.
But still let me know, if 650w corsair, can do this job or not ?..
Regards..
dep5kor
01-02-2010, 11:20 AM
#44 (permalink)
Super Moderator
Why did you get that PSU. It is famous for being not good. CM Extreme series. ASAP, remove all OC, and do not stress the system. Get it changed. A 550W Corsair is more than enough.
01-02-2010, 12:13 PM
#45 (permalink)
Corsair HX550W enough? he gt a water block with maybe radiators.
OFF TOPIC: looks like it has became a habit of the newcomers here to ignore the advice of senior ThinkDigitians or even the new 1s like me.
01-02-2010, 02:51 PM
#46 (permalink)
Super Moderator
He will not even reach 400W with a rad in there.
01-02-2010, 06:18 PM
#47 (permalink)
ok, thanks for the info. thought water blocks & radiators consume lots of power.
08-02-2010, 09:40 AM
#48 (permalink)
Hey Guys,
Thanks a lot..I got Corsair 750W as a replacement for CM EX600W.
But do you guyz have any details on Cable management inside CPU.
Regards..
08-02-2010, 10:02 AM
#49 (permalink)
Super Moderator
Well..you have the HAF932, what more can I say. One of the best full ATX towers. It has excellent cable management. Buy a bunch of cable ties (full packet), and start off. Try to keep the maximum cable hidden. The cabinet has nice ducts. It takes patience and thought. Though fun.
15-02-2010, 01:34 PM
#50 (permalink)
Thanks for the support.
Recently my friend got a i7 920 with Asus Rampage & his doubt is can he have 2 x 2Gb DDR3 1600 Corsair XMS3 for the same, which cost around 6-7k.
Please let me know asap.
15-02-2010, 02:08 PM
#51 (permalink)
Super Moderator
It would be more wise to use 2 x 3GB to optimize the X58 chipset. Read: tri-channel.
06-04-2010, 02:50 PM
#52 (permalink)
Just let me know, if i can use 2x2GB 1600 Corsair & 2x2GB Gskill RAMs for the same conf.
