| Forum |
#1 (permalink) |
I want to buy a basic mp3 player for my younger brother. But i am confused .. my budget is 2- 2.5k i know i will get ipod shuffle with that budget but i need with few features like FM with recorder .. I was thinking bout Creative zen stone plus .. but i wanted to ask you ppl before buying .. Or you can sugest me other players also.. but plz ASAp.. Thanks in advance
AMD X4 630 A M4A785TD-V EVO DELL ST2210 CM ELITE 310 FSP SAGA II 400W WD 500GB TRANSEND 2 x 2GB DDR3 HP DVD APC 550V Canon Elura Mini DV & S2 IS SONY PS2 iPod shufle N73 ME & Ngage QD |
#2 (permalink) |
Crowman
Phiips GoGear 1GB is also an option. I'm using it and I like it, but beware, it has USB transfers and charging and is a pendrive basically so viruses can ruin things. Also, it gives very low transfer speeds. But, as a music player, I have no complaints, especially with its battery. Long battery life, really! You will need better earphones than the ones you get in the bundle as most mp3 players have rathr bad earphones bundled.
Like a post? Use the reputation button.
Abusive, offtopic post? Use the report post button. Read before messaging any moderator for any query: FAQ + answers for new members Read all the sticky threads before asking any type of query. Most basic questions are answered in those. |
#3 (permalink) |
San Disk Sansa 2 GB + 2 GB microSD card + Creative EP630.
Or any other player + Creative EP630. Please don't spend all your funds only on the player alone - The bundled earphones are crap. That extra 800 for earphones is worth spending for instead of some fancy features!
Intel D930&945GNTL| 2x1GB 667 Mhz(Transcend+Kingston)| 500GBSeagate+200 GB WD|Zotac 9600GT Amp!| Zebronics Platinum 400W|Dell SP2208WFP|Logitech z5500| Lite-onDVD-RW+LGDVD-R |
#5 (permalink) |
Simply a DIGITian
Wat about Transcend V30?? It has FM Radio(Save upto 20 Channels), 2GB inbuilt memory(Not expandable), Voice Recording, FM Recording, Line-in Recording and more.....I'm satisfied with bundled earphones.
kIlL pIrAcY....................sTeAl OrIgInAl Cd's
| Bookmarks |
| Thread Tools | |
| Display Modes | |
