Old 04-09-2009, 07:54 PM   #1 (permalink)
Default System Upgrade--Help me !!!!
hey all.. I would like to have a configuration of either 2 or 3 GB RAM for my Gateway Laptop MX 6926b and Upgrdation for my hard disk..
my system details :
Windows Vista 32 Bit
• Currently Installed Memory: 512MB always system is slow..
• Available Memory Slots: 0
• Total Memory Slots: 2
• Dual Channel Support: Yes
• CPU Manufacturer: GenuineIntel
• CPU Family: Genuine Intel(R) CPU T1350 @ 1.86GHz Model 14, Stepping 8
• CPU Speed: 800 MHz
torrent08 is offline
Old 11-09-2009, 10:43 AM   #2 (permalink)
Default Re: System Upgrade--Help me !!!!
You already have a laptop which you want to upgrade or you want to buy a new laptop?
hell_storm2006 is offline
Old 15-09-2009, 04:05 AM   #3 (permalink)
i want a upgrade to my laptop
Old 15-09-2009, 04:21 AM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
addition of 2Gb RAM should be enough and then upgrade to windows 7 which is lot less resource hungry (release october 22nd)!
desiibond is offline
Old 15-09-2009, 10:18 AM   #5 (permalink)
For anything on a laptop would suggest you talk to your customer care support first. I suspect that you have an old laptop coz 512MB of initial RAM came around 3 years ago! Am i right?
