Old 03-09-2009, 09:21 PM   #1 (permalink)
soyab0007's Avatar
Default URGENT CPU TEMP 127 DEGREE
From the last few days my pc shutdown automatically.
I go to bios and enable system fan fail warning and saving to cmos.
It gives me a continuous beep.
And today when i see my pc health status cpu temp is 127..
After going on windows i had installed software speed fan 4.35 it also shows temp 3 (127 degree) while temp1 & temp2 is under 45
after successfully shutting down the pc .
Pc goes off but psu & heat sink fan spins
what should i do
plz reply me urgent
soyab0007 is offline
Old 03-09-2009, 10:18 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: URGENT CPU TEMP 127 DEGREE
Looks like you may need to check the CPU fan. if possible apply thermal paste and reinsert CPU cooler properly.
btw, what's the config?
desiibond is offline
Old 03-09-2009, 11:10 PM   #3 (permalink)
BSD init pwns System V
hellknight's Avatar
abey speed fan is wrong.. its not detecting the sensors well.. mera bhi 127 Deg hi dikhata hai.. but if in doubt then go to your friend's home and see whether his CPU is also running at 127 Deg according to speed fan..
My blog :- www.openenclave.wordpress.com
hellknight is offline
Old 03-09-2009, 11:27 PM   #4 (permalink)
soyab0007's Avatar
I had put thermal paste but that doesnt works..
intel dual core 1.6ghz (2.5 years old)
gigabyte GA G31M S2L (7 months old)
1gb ram 800mhz Transcend (7 months old)
i ball 400w (7 months old)
Posted again:
Old 04-09-2009, 12:01 AM   #5 (permalink)
Super Moderator
asingh's Avatar
Posted again:
Use RealTemp to monitor temperatures...!
asingh is offline
Old 04-09-2009, 12:35 AM   #6 (permalink)
there would be an option in the bios also for not shuting down the pc when a fan fails ...disable it
and if ur pc constantly afterward then it means its overheating
allmighty is offline
Old 04-09-2009, 11:54 AM   #7 (permalink)
Point Blanc
oye at 127 degree all your components will fry up and die in no time. touch the component with your own hand if it burns hehe
acewin is offline
Old 04-09-2009, 06:01 PM   #8 (permalink)
Super Moderator
asingh's Avatar
Yes correct...and as I mentioned, SpeedFAN could be reporting incorrect. Try RealTEMP.
Please do not do this. This is the last fail-safe you have, to protect the chip. For sure you will burn it/short it.
asingh is offline
Old 06-09-2009, 05:42 PM   #9 (permalink)
soyab0007's Avatar
Old 06-09-2009, 07:35 PM   #10 (permalink)
Super Moderator
asingh's Avatar
could you change that huge image...to a smaller version. Cannot read it.
asingh is offline
Old 08-09-2009, 02:39 AM   #11 (permalink)
127 degrees is wrong....its an erroneous reading speedfan is posting.
Check for other stuff....are you saying the cpu fan n psu fan spins but u dont get a display and the monitor light keeps on blinking??
@127 degrees things would be burning.
Check if u have inserted the rams properly.....clean the slots with soft cotton cloth...reinsert..
heavyarms is offline
Old 08-09-2009, 06:46 AM   #12 (permalink)
soyab0007's Avatar
My pc works smoothly, windows load properly..
But the main problem is it shutdown automatically and in bios temp shows 127 degree
Old 08-09-2009, 07:13 AM   #13 (permalink)
Bond, Desi Bond!
desiibond's Avatar
you better apply thermal paste and insert cpu heatsink and fan properly. that should fix the problem.
Old 08-09-2009, 09:51 AM   #14 (permalink)
Super Moderator
asingh's Avatar
Can you do the two things FIRST:
1. Use RealTEMP to report your temperature. Set TJMax = 100. Post a screen shot of the temperature here, running Prime95 via RealTEMP. If you cross 100C, stop the test. But do make the screen shot first.
2. As all have been suggesting replace your HSF apply TIM. Clean the previous application with isopropyl alcohol. Then try (1).
asingh is offline
Old 08-09-2009, 02:28 PM   #15 (permalink)
Temps cant be 127degrees...the chip would have been burnt off by now it if was...
@op u saying u have disabled the thermal shutdown from the bios even then ur pc shutsdown from windows??
Old 08-09-2009, 04:39 PM   #16 (permalink)
Hanging, since 2004..
tarey_g's Avatar
I too get 127 deg as wrong reading, dont worry.
Digit forum without nagging ads and with new features = http://www.thinkdigit.com/forum/showthread.php?p=945285
tarey_g is offline
Old 08-09-2009, 06:02 PM   #17 (permalink)
Intel OCer
amitash's Avatar
Do a BIOS update
My site: collegeclassroom.org
amitash is offline
Old 08-09-2009, 10:40 PM   #18 (permalink)
soyab0007's Avatar
But pc shutdown automatically
what to do
