Old 01-09-2009, 03:35 PM   #1 (permalink)
>:)I-):(|)8-X
Charan's Avatar
Default SMPS Replacement
We have a C2Q6600 based computer which we run as a server (Windows 2008), We need to replace the SMPS on it. a 400-500W SMPS should do. Can any one recommend me a good SMPS for system stability. budget 2-3K
i5 2400 | DH67BL | G.Skill Ripjaw 4 GB | FSP SAGA II 500W | CM 430 Black Elite | MSI R6850 Cyclone PE/OC | XBox 360 Controller | 21.5" Samsung Sync Master 2233 | 4 Mbps UL
Charan is offline
Old 01-09-2009, 03:49 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Thumbs up Re: SMPS Replacement
I would say CoolerMaster ExtremePower 500W....
Its quoted as 2839/- at Lynx-india
http://www.lynx-india.com/beta/index.php?productID=706
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is offline
Old 01-09-2009, 07:38 PM   #3 (permalink)
Default Re: SMPS Replacement
Get corsair cx400 or seasonic 380w minimum costs rs 3k to 3.2k
if you would the give full config we can advice better
MSR@THNIK is offline
Old 01-09-2009, 10:25 PM   #4 (permalink)
Extreme Power would be a problem! Stick with corsair! Probably the best PSU brand around! Do you have a GPU? If yes, which one?
hell_storm2006 is offline
Old 02-09-2009, 02:14 PM   #5 (permalink)
>:)I-):(|)8-X
Charan's Avatar
Here is the system config.
Intel C2Q 6600
Intel GD45ID - Motherboard
4 GB RAM
17" Dell Monitor
Two Segate 250 GB SATA HDD
USB Modem (Teltonika G10) (Always connected)
Mercury 400W SMPS.
The server is connected to our main 3KVA UPS which give backup of minimum 2 hrs for 5 PC's
Charan is offline
Old 02-09-2009, 04:26 PM   #6 (permalink)
Lightbulb Re: SMPS Replacement
Intel C2Q 6600
4 GB RAM
17" Dell Monitor
Mercury 400W SMPS.
Go for only Corsair 400W Power Supply (CX400W) only.
Mr.Digital is offline
Old 02-09-2009, 05:12 PM   #7 (permalink)
damnbadman666
damngoodman999's Avatar
Corsair CX400
AMD Phenom 2 940 @ 3.4Ghz [Hyper 212+] MA790GP-UD4H OCZ DDR2 2x2GB Asus GTX 560ti 1TB SATA2 LG 20" LED Razer DA mice RED HOT cabby
damngoodman999 is offline
Old 02-09-2009, 07:43 PM   #8 (permalink)
You don't have a GPU?
Old 02-09-2009, 08:32 PM   #9 (permalink)
>:)I-):(|)8-X
Charan's Avatar
^^ No.
I will check out the price of Corsair CX400.
Charan is offline
Old 02-09-2009, 11:53 PM   #10 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
I don't think will not need anything greater than 250W
Intel C2Q 6600 - 110W
Intel GD45ID - Motherboard - 30W
4 GB RAM - 20W
Two Segate 250 GB SATA HDD - 20W
USB Modem (Teltonika G10) (Always connected) - 10W
jin files ka koi server nahi hota unka bittorrent hota hai
chesss is offline
Old 03-09-2009, 03:54 PM   #11 (permalink)
But the thing is there is no model available for 250W usage from the reliable brands!
Old 03-09-2009, 05:30 PM   #12 (permalink)
bigdaddy486
Posts: n/a
why is it that local models are cheaper at .5k while others are @ 2-3k?
i can understand tat they r branded but why this much huge difference?
is tthere anything special?
Posted again:
Old 03-09-2009, 05:44 PM   #13 (permalink)
Crowman
Krow's Avatar
^They are low quality and unreliable.
@ OP - Gigabyte 460W @ 2.5-3k also seems to be good. I saw the price on lynx.
ADDED : http://www.lynx-india.com/beta/index...byte-460w-smps
Its 2.2k!!!
Like a post? Use the reputation button.
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 03-09-2009, 07:01 PM   #14 (permalink)
>:)I-):(|)8-X
Charan's Avatar
Thanks for the updates guys. I will purchase a Corsair CX400.
@Mods , please close this thread.
Charan is offline
Old 03-09-2009, 08:01 PM   #15 (permalink)
chesss's Avatar
Its probably because the costly ones are imported maal .
chesss is offline
Old 04-09-2009, 10:18 AM   #16 (permalink)
The capacitors Japanese solid state capacitors, not the Chinese one's local one's use, which last a lot longer than the Chinese one's, hence they are reliable and safe! Plus, better build quality!
Old 04-09-2009, 11:51 AM   #17 (permalink)
Point Blanc
but anyhow there is someone who is not good maths, and has lesser understanding of cheap, and decent price, you cannot just say that being imported they are costlier.
zebronics is also a local brand and manufactures good quality product and is priced compared to those imported products.
@bigdaddy486, as hell_storm said, good electronic components used, add to it better warranty than local products which offer max of 6 months, and infact their warranty is no good warranty. whereas good PSU brands give you a minimum of 3 year of warranty. and some giving 5 year
acewin is offline
