Old 01-09-2009, 09:51 AM   #1 (permalink)
bigdaddy486
Posts: n/a
Default Computer dead?
Hi..
i have a custom-vuild computer with
intel core2duo 6300
nvidia 8400GS
1GB RAM (512x2)(1-550mhz, other-667mhz)
motherboard intel-DG965WH
power supply-400W zebronics
also have 2 dvd drives, 80 gigs hard drive and a extra network card and tv tuner........
My problem is that my computer is not turning on.......
i think it is a problem with power suppply but the real problem is that after the computer is turned off for a long period and then turned on, it will work for some minutes or max of 1 hour andthen turn off again.....
then, if i turn on, the computer wont turn on at all..........
but last day, it worked for abt 6 hours and then again the same problem is repeating.....
Can anyone plz help me??
Old 01-09-2009, 09:56 AM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: Computer dead?
I think the prblm is with SMPS.
Power on ur PC, open ur cabinet and notice the mobo LED whether the power is thr.
I dnt think 400W is ur prblm. May b sumthing wrong with ur SMPS. Or simply loose connection.
Wait for other members to reply.
kIlL pIrAcY....................sTeAl OrIgInAl Cd's
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline
Old 01-09-2009, 09:59 AM   #3 (permalink)
bigdaddy486
Posts: n/a
thnx for immediate answer..
i forgot to say that the motherboard light donot turn on..........
once the computer is turned on and then off, the lightblinks and gradually turns off for a long period....
Old 01-09-2009, 10:05 AM   #4 (permalink)
Simply a DIGITian
Thn its a sure prblm of SMPS as the power is not coming to ur mobo.
Call the hw guy to check ur SMPS or u can check urself if u know how to use multimeter.
If u find it faulty get it replaced(if under waranty) or its time to buy a new one.
But wait a day or two and lets c what other membres suggest.
Old 01-09-2009, 10:10 AM   #5 (permalink)
Crowman
Krow's Avatar
A simple tip:
Clean out all th dust in ur cabby with a dust-blower or a vaccuum cleaner and a dry cloth/brush.
Loads of times my PC didn't boot and I cleaned dust and suddenly it booted.
Regarding the light not turning on, chk the cable of cabinet LED, which connects mobo to cabby. It may be loose or smthn.
If after all this, PC doesn't boot, then it may be SMPS problem.
Like a post? Use the reputation button.
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 01-09-2009, 10:29 AM   #6 (permalink)
Zebby PSU.... What do you expect!!! Lucky that the PSU died before frying your PC!!!
hell_storm2006 is offline
Old 04-09-2009, 11:45 PM   #7 (permalink)
bigdaddy486
Posts: n/a
thnx guys.....
replaced smps, working fine now...........
