Old 30-08-2009, 02:37 PM   #1 (permalink)
Tech addict
surinder's Avatar
Default Suggesions reqires for Mobo procy combo
Hi guys I'm going to have a chance to get an upgrade without spending a single penny for so. A good deal of 8K has been offered to me for my existing E7300 + Asus P5KPL-CM by an INTEL fan.Although my scheduled upgrade for nehalem is still four to five months away,but I found no harm to accept this offer and swich to AMD's AM3 platform specially with no extra cost.
So here is my suppose to be the next combo.
Proccy AMD Phenom II X2 545 @4.8K
Mobo Bioster A760G M2+ @2.8K
And of course I shell add another two GB of RAM.
I have half a month left for upgrade and I'm looking for good advise on other considerable VFM combos under 8K (excluding RAM price).My system runs twelve hours a day and my uses pattern is something like that 60% downloading plus surfing 20% HD videos and 20% for gaming.
surinder is offline
Old 30-08-2009, 03:06 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Suggesions reqires for Mobo procy combo
I would pick a solid 780G mobo from gigabyte or ASUS. I don't trust in cheap grade manufacturing process used in these sub 3k mobos.
desiibond is offline
Old 31-08-2009, 01:05 AM   #3 (permalink)
GeekyBoy's Avatar
You could get a Biostar 780g motherboard for about Rs 3200- theyre cheap but pretty reliable.....but if you are interested in unlocking the 2 extra cores in the Phenom II x2, then you have to get the Phenom II x2 550 Black edition processor instead of the one that you have mentioned.
You also need a motherboard with ACC(advanced clock calibration).Only 785g and 790 chipsets support it. Theres a biostar 785g at Rs 4100, you could get it.
This may require to up your budget a bit, but an unlocked phenom II x2 performance is similar to that of a quad core.
For a list of batch numbers of successful processor unlocks, go here :
http://www.xtremesystems.org/forums/...d.php?t=227004
Intel Core i3 2100 //4GB Corsair DDR3 1333 RAM //Intel DH61WW//Sony AD-7260S DVD-RW//Samsung 2033SW Monitor//Windows 7//Seagate ST3250310AS 250GB HDD
GeekyBoy is offline
Old 31-08-2009, 08:39 AM   #4 (permalink)
Tech addict
surinder's Avatar
Ya Desiibond I'm agree with you Bioster A760G M2+ may not be that reliable but then again I have to stick with it for just six months at most and warranty period on this board is much more then that.
Geeky Boy your suggested approach feels really mouth watering but it is very dicey because other two cores which are factory locked may be or may be not functional after unlocking so extra 1.8K can go in vain and warranty may be also gone as well although I'm not sure about it.
BTW anyone can please figure out percentage of chances for other two functional cores as if it is more likely to have four fully functional cores on Phenom II x2 550 BE after unlocking other two cores then I shell go for it and if chances are less then say 60% then I shall stick with A760G + Ph II X2 545.
surinder is offline
Old 31-08-2009, 09:29 AM   #5 (permalink)
Tech addict
surinder's Avatar
Hang on guys I got the price of Bioster A785G is 3.2K and Phenom II X2 BE goes for 5.2K. Well now I'm more towards this setup and shell test my luck to unlock other two cores as difference is now just 0.8K with A760G + Ph II X2 545 combo. So let me know if there are any hiccups in this combo and which version of BIOS is more likely to come up with rosy results. Have anybody tried and got success on 785G chipset as yet?
surinder is offline
Old 31-08-2009, 01:26 PM   #6 (permalink)
One thing... If you are going for an upgrade to Core i7 in four or five months. Lets say even 6 months, I would say that hold on to what you have. Sell them off when you are going for the upgrade and add the the cash into the upgrade! The offer you mentioned is good, but just to put it may not cost you a penny but it certainly doesn't get you anywhere in the upgrade ladder. And resale value of Intel is higher than AMD i think!
hell_storm2006 is offline
Old 31-08-2009, 03:01 PM   #7 (permalink)
Tech addict
surinder's Avatar
Hell_storm2006 well A785G board + Phenom II X2 550BE plus two more unlocked cores (if my luck works my way) by adding just 0.4K for upgrade from what I have, I don't think is a bad enough offer to refuse.
surinder is offline
Old 04-09-2009, 09:29 AM   #8 (permalink)
Point Blanc
yup, certainly not a bad offer
acewin is offline
Old 04-09-2009, 10:09 AM   #9 (permalink)
Well if that mobo has an updated BIOS then forget unlocking cores! The rig you mentioned is certainly good so if you are fine with it you can certainly go with it. i7 rigs would become a little bit cheaper in that time. Maybe the processor wont be cheap, but DDR3 RAM's will certainly see some drop in prices!
Old 04-09-2009, 10:12 PM   #10 (permalink)
Tech addict
surinder's Avatar
So is it my best bet around 8K or any other combo is there to consider for my uses ?
surinder is offline
Old 05-09-2009, 12:00 AM   #11 (permalink)
Crowman
Krow's Avatar
Best bet 100%!!!
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
- by kool
- by ax3
