Old 29-08-2009, 09:28 PM   #1 (permalink)
GeekyBoy's Avatar
Exclamation Upgrading: Please help me to choose the correct components--
Look guys. I upgraded my pc about 3 yrs ago. U can find my config in my signature.
My pc has become a bit slow now, I cant play a single new game release.
I have a budget of Rs 10000
I was considering to upgrade the following:
Processor:AMD athlon x2 245 Rs 3500
Motherboard: Biostar 790GX RS 4500
RAM: 2GB DDR2 Rs 1200
Cabinet: Zebronics Bijli Rs 1500.
But as a second option, instead of upgrading the processor, board and ram, I thought of buying a Ati 4670 graphics card(Rs 4200) and the cabinet(zebronics bijli with stock smps), {Coz da cheaper da better}
So which will give me more gaming performance? Or is there anything else
I should upgrade? Please help me guys......I cant even play nfs undercdover!!
Intel Core i3 2100 //4GB Corsair DDR3 1333 RAM //Intel DH61WW//Sony AD-7260S DVD-RW//Samsung 2033SW Monitor//Windows 7//Seagate ST3250310AS 250GB HDD
GeekyBoy is offline
Old 29-08-2009, 09:36 PM   #2 (permalink)
Crowman
Krow's Avatar
Default Re: Upgrading: Please help me to choose the correct components--
^Good choice of config!
Please check the price of 785G based mobo from Gigabyte. It should give you even better gfx I suppose. I would recommend that you increase your budget to about 15k and get a decent PSU with the package like Antec EA 650 or Seasonic 460W or Corsair VX450W.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 29-08-2009, 09:41 PM   #3 (permalink)
GeekyBoy's Avatar
Thnx
Which gives more grafix performance: My old athlon 3000 with ati 4670 discrete graphics card or the new AMd athlon II X2 245 with 790gx onboard grafix?
And as I am a student, dad wont let me up da budget much....max will be 12000.....but as i said....the lower the better...
And can stock psu of Zebronics bijli handle Ati 4670?
Thnx
GeekyBoy is offline
Old 29-08-2009, 09:53 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
I tried to run HD4770 on my old Athlon 3000+ (venice core) but the processor proved to be a too much of a bottleneck. My suggestion would be wait till 785G is fully available and then upgrade to
Phenom II or Athlon II X2
758G
DDR3
9600GT
desiibond is offline
Old 29-08-2009, 09:54 PM   #5 (permalink)
Crowman
Krow's Avatar
^It might just be able to handle it but it will get overloaded for sure after a period of time and will harm other components. For now, if you want to game only:
A). Open your cabinet and clean all the dust in it, preferably use a vaccuum cleaner or a simple dust blower with a dry cloth should do.
B). Get a decent GFX card like the 4670 512MB GDDR3 or 9600GT 512MB GDDR3, and game happily. I dunno if that PSU will handle it still
C). I would recommend you wait for some time before you upgrade ur CPU and mobo.
Krow is offline
Old 29-08-2009, 09:56 PM   #6 (permalink)
GeekyBoy's Avatar
758G
DDR3
9600GT
How much of a bottleneck will it be? Can I play GTA4?
And I dont have the money to buy an smps.....so 9600gt is out of the question...(i hope stock psus can run 4670)
Posted again:
Ok....thanks......but what harm will it do??
GeekyBoy is offline
Old 29-08-2009, 10:04 PM   #7 (permalink)
Bond, Desi Bond!
desiibond's Avatar
if I am right, HD4670 and 9600GT take same amount of power. look for one that comes with GDDR3 as it will take little less power than one that is using GDDR2.
Old 29-08-2009, 11:21 PM   #8 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
9600GT can run with and without extra +6 pin pcie power
Posted again:
GTA 4 is more dependent on processor than GFx card , in my PC(AMD 3500+,512MB RAM , 8400GS) it was sure unplayable (RAM is bottelneck here)
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 30-08-2009, 12:55 AM   #9 (permalink)
GeekyBoy's Avatar
But most of the review sites say otherwise....anyway, I was hearing about new launches in the graphics card arena.....so should a wait a little before i buy the 4670 or 9600gt?
GeekyBoy is offline
Old 30-08-2009, 01:19 AM   #10 (permalink)
Bond, Desi Bond!
desiibond's Avatar
new ones are gonna cost around 10k. you can wait another week to see if there is anything else in the bag.
Old 30-08-2009, 10:21 AM   #11 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
http://www.nvidia.com/object/product...9600gt_us.html
See in the specification , there are 2 columns , one for 96W and other of 59W , scroll down in the bottom and see they have diff requirments , they are of same card but will work faster if additional power is supplied .
so someday if you decide that you need extra power just add psu and you will get wooping 50MHz increasement
Old 30-08-2009, 11:09 AM   #12 (permalink)
Om Ma Ni Pä Me Hum
phuchungbhutia's Avatar
Does your mobo support the graphics card you mentioned . . I doubt it . .
Om Ma Ni Pä Me Hum: (perfection of-)
Om: generosity,- Ma: pure ethics,-Ni: tolerance n patience.- Pä: perseverance,- Me: concentration,-Hum: wisdom... Using Opera Mini Airtel NOP
phuchungbhutia is offline
Old 30-08-2009, 01:19 PM   #13 (permalink)
GeekyBoy's Avatar
It has a pcie x16 1.0 slot.....I've heard Pcie 2.0 cards are backward compatible with PCIE 1.0....so I guess it will run......what do you guys say??
GeekyBoy is offline
Old 30-08-2009, 01:37 PM   #14 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^yes. that should be fine.
Old 30-08-2009, 01:45 PM   #15 (permalink)
GeekyBoy's Avatar
I think thats the green edition of 9600Gt......but how is the availability? I dont hear anyone talking about the green edition and stuff?
GeekyBoy is offline
Old 30-08-2009, 03:53 PM   #16 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
^^damn if u are saying is true then my 9600gt is lost .
i had purchased 9600gt few days ago only , i will try and post results what happned
- by kool
- by ax3
