Old 28-08-2009, 06:23 PM   #1 (permalink)
Exclamation Mother board upgrading help needed... urgent
i am planning to upgrade my pc .
the config is
p4 3.0 ghz ht processor (775 socket)
dg 101 ggc mother board ( very bad mother board )
256 ddr ram
Would this processor work fine with ddr 2 rams and new mother boards , i also need a mother board with serial port , cos i need to run billing software at my office which need serial port for printing in dos format ( my software programmer is not likely to make any change in near future )
if the processor is not compatible please suggest me a good combination
Budget
proc+ ram + mobo under 8 K Rupees
Please help me , i need to do shopping soon
Thanks
www.LiveGlamour.com
eureca_eureca is offline
Old 28-08-2009, 08:47 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Mother board upgrading help needed... urgent
you may need to look at G45 motherboards. But it's difficult to find boards that support DDR as DDR2 and DDR3 have become mainstream now.
desiibond is offline
Old 30-08-2009, 12:02 AM   #3 (permalink)
Would my proc support ddr 2 ram ?
www.LiveGlamour.com
Old 31-08-2009, 01:21 PM   #4 (permalink)
E5200 - 3.2K.
G31 mobo. Dont know the model. 2.5K.
Transcend 2GB RAM. 1.5K.
Total - 7.2K.
hell_storm2006 is offline
Old 01-09-2009, 04:46 PM   #5 (permalink)
Originally Posted by hell_storm2006 View Post
E5200 - 3.2K.
Total - 7.2K.
No serial port for this mobo , its a must for my dot matrix dos printing
2.5 is a good price i think !
Thanks hell storm
www.LiveGlamour.com
- by kool
- by ax3
