Old 26-08-2009, 10:40 PM   #1 (permalink)
Manickaraj's Avatar
Default CM 690 cabinet
I am gonna buy a cabinet tomorrow. Budget is maximum Rs. 2k. ll CM690 fit my budget.
LL IT PROVIDE ENOUGH COOLING FOR MY RIG???????
Intel C2Q Q8400 @ 2.66 GHz, ASUS P5QL-CM mobo, CORSAIR XMS2 2x2GB (800MHz), XFX 4870HD 1GB DDR5, 500 GB SEAGATE HDD (32 MB buffer), COOLERMASTER EXTREME POWER 600 W.
Manickaraj is offline
Old 26-08-2009, 11:56 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: CM 690 cabinet
Yes..it will provide excellent cooling for your rig.
You can mount 7 fans...120mm x 6, and one smaller one.
Price is: ~Rs 4200
asingh is offline
Old 27-08-2009, 12:05 AM   #3 (permalink)
Democracy is a myth
rhitwick's Avatar
Thumbs up Re: CM 690 cabinet
Its best for any rig.
But doesn't come under ur budget.
Its AFAIK over 5k
Try CoolerMaster Elite 330 or a few of same Elite series.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 27-08-2009, 06:57 AM   #4 (permalink)
Manickaraj's Avatar
Price is: ~Rs 4200
I thought only the black edition would burn a hole in the purse? Isnt the standard version would cost around Rs. 2k...
Old 27-08-2009, 08:53 AM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
CM 690 minimum price is 4.5k (tax extra) afaik. For 2k budget you can look at high end zebronics cabinets and Cooler master Elite series cabinets.
desiibond is offline
Old 27-08-2009, 10:00 AM   #6 (permalink)
Super Moderator
asingh's Avatar
There are two editions for CM690.
1 . The standard version (black) for approx 4.2K or 4.2K+350 for transparent side panel.
2. nVidia edition -- which is around 12K. This will burn the hole...!
asingh is offline
Old 27-08-2009, 10:25 AM   #7 (permalink)
Well get this.... CM690 comes in three types:
CM690 normal one's come around 4.3K.
CM690 with transparent side panel around 4.7K.
CM690 nVidia edition comes for 6.8K. All prices are Mumbai one's. So if you are in some other city it may vary!
None of the cabinets are within 2K. So either increase your budget or say bye bye to it!
Around 2K the best one you can get would be CM Elite 335.
hell_storm2006 is offline
Old 27-08-2009, 01:07 PM   #8 (permalink)
himadri_sm's Avatar
well i think the zebronics Antibiotic & Reaper are better
View my Portfolio here-
Pixels and Polygons | On Linkedin | On Facebook
Available for freelance. PM me for details.
MSI 890 GXM G65, Phenom X6 1055T, G.Skill 1600Mhz "Ripjaws" 2x2gb Kit, MSI GTX 470, WD Black 500Gb, NZXT Gamma, Corsair Vx550, Hp 22x DVD-Rw, Benq G2420HD, Logitech Mx-518, Xbox 360 Gamepad for PC
himadri_sm is offline
Old 27-08-2009, 01:18 PM   #9 (permalink)
mac555's Avatar
also check NZXT Alpha...it from classic series and below 2000...
mac555 is offline
- by kool
- by ax3
