Old 26-08-2009, 08:33 PM   #1 (permalink)
Thumbs up Wireless ADSL Routers
hii frnds,
i'm using BSNL 250 home plan and i have got an ADSL modem from BSNL but now i want to upgrade my internet connection to unlimited plan and planning to use it on my lappy.
Help me to choose a good ADSL router, shud i get the router from BSNL or from outside like belkin or netgear etc... whats the diff..? there is a huge price diff between BSNL and belkin Routers, don't know why.?
my laptop details
Lenovo IdeaPad Y510
Processor Intel® Core™ 2 Duo T5750 (2GHz 667MHz 2MB)
Operating system Genuine Windows Vista Home Premium
Memory 2 GB PC2-5300 DDR2 SDRAM 667MHz
Hard drive 250GB 5400
Communication Intel Wireless WiFi Link 4965AGN
let me know which ADSL routers will support my laptop and what will be the price of it.?
Thanks
Kolkata
Saurav
Best Possible PC Configuration or Dream PC -
http://www.thinkdigit.com/forum/showthread.php?t=51297
sr_garg is offline
Old 27-08-2009, 09:08 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Wireless ADSL Routers
Check Linksys ADSL2+ wireless gateway. costs around 3k and is pretty good model with solid support and very easy to use connectivity interface
desiibond is offline
Old 27-08-2009, 12:35 PM   #3 (permalink)
Always Fresh!
shri's Avatar
According to me go with BSNL routers.
Firstly - as you said - they are cheap.
Second most important point is BSNL so called 'technicians' only know to configure and setup routers available with them. So when something goes wrong (which will) and a 'technician' comes to your house for repairs, his first words will be "What is this? We don't provide support for this..."
BE YOURSELF :)
http://everythingoutthere.co.cc
shri is offline
Old 27-08-2009, 01:22 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^With routers like Linksys, you don't have to rely on BSNL uncles. You just give a call to Linksys and the response will be much more professional.
Old 27-08-2009, 06:44 PM   #5 (permalink)
adi007's Avatar
First of all change your plan
Trust me when i say 250 plan is the crappiest plan ..it charged me 4000 rs when i exceeded the limit..1 GB is not enough for casual browsing too
doiteasily.com ►easy way(s) to do certain things
Tech Word of the day : ADSL
Aditech Blog ► There is something for everyone
Terminal Command of the day
regtweak.info ► Windows Registry hacks and tricks
adi007 is offline
- by kool
- by ax3
