Hi,
I have a creative Inspire M2600 2.1 Speaker System. For the past few months I'm hearing a buzzing sound when the Speaker is not in use. I get the sound from the Left side Speaker. When I changed the connection cables in the sub-woofer from left to right, then I get the sound from right side speaker. Only when the speaker sound is reduced to zero "0" in the speaker / when the speaker is switched off I don't get that buzzing sound.
When the sound volume is kept normal then I start hearing the buzzing sound. I even re-installed the OS and I get the same buzzing sound in any one of the speaker. The problem is not in software side, its the speakers that should be repaired.
The warranty of the speakers are over. I inquired but can't find a creative service center in Bangalore.
Is there any authorized service centers for "creative" speakers in Bangalore to repair it?
Regards
Rafales
