Old 22-08-2009, 07:00 PM   #1 (permalink)
Manickaraj's Avatar
Unhappy New ASUS P5QL-CM chassis intrusion detection problem
I bought this mobo last week.
It has chassis intrusion detection system and this system displays a fatal error stating that chassis intrusion detected.
I know the use of this system so dont explain all those stuffs.
Pls give me a solution. There is no info abt this in the manual either.
Has anyone experienced a similar problem?
Manickaraj is offline
Old 22-08-2009, 07:36 PM   #2 (permalink)
Default Re: New ASUS P5QL-CM chassis intrusion detection problem
its a problem with power supply
awww is offline
Old 22-08-2009, 09:31 PM   #3 (permalink)
Super Moderator
asingh's Avatar
Remove the wire header from the chassis intrusion pin header....! Then try...
asingh is offline
Old 22-08-2009, 09:55 PM   #4 (permalink)
Manickaraj's Avatar
It's a new power supply and i also tested this with another PSU.
Posted again:
Can u be more specific. Illustrate with a pic if possible. Because i changed the jumper settings too but invain. Manual has nothing abt this.
Old 22-08-2009, 10:51 PM   #5 (permalink)
my asus board kept showing this same error message it turned out that i didnt connect the powersuply pins correctly
better check all the connectors i have no other ideas sofar
awww is offline
Old 22-08-2009, 10:58 PM   #6 (permalink)
Super Moderator
asingh's Avatar
Posted again:
Does not the manual mention anywhere...chassis intrusion connector..???
asingh is offline
- by kool
- by ax3
