Old 21-08-2009, 02:08 PM   #1 (permalink)
Default 1 TB HDD Suggestion
Hey guys and gals...
i am looking for a 1TB HDD
Not quite in touch with current hardware, so if anyone has recently bought a 1TB HDD or has been using it for sometime, Suggest which one is the one i should go for..
thanks
realdan is offline
Old 21-08-2009, 02:16 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: 1 TB HDD Suggestion
If you have 6.5k, go for Western Digital Caviar Black 1Tb HDD. This one's superfast but only available at a high price
option 2: Go for WD caviar green or seagate 7200.12 1Tb HDD for 4.5k
option 3: Go for two 500Gb Seagate/WD HDDs, each one 2.7k. This one reduces the risk of data loss. After all 1Tb is lot of data.
desiibond is offline
Old 21-08-2009, 04:08 PM   #3 (permalink)
thanks for the info..
looks like option 2 seemed to be better in my case.. dont want to have too many harddisk connected..already have one other 250gb one...
realdan is offline
Old 21-08-2009, 04:50 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
few days ago, I bought WD 1 TB green for Rs. 4500/- (Negru place, Delhi)
ravi_9793 is offline
Old 23-08-2009, 01:50 PM   #5 (permalink)
go for wd 1tb black
Posted again:
green is also gud 32 mb
Posted again:
wd 1tb green is also gud 32 mb
Aman31 is offline
Old 23-08-2009, 09:44 PM   #6 (permalink)
Am here for u
Vensanga's Avatar
Go for WD 1 Tb green and which one are you gonna use for back up and for the system??
Acer aspire TimelineX 4820T, Nokia 5800XM
Vensanga is offline
Old 23-08-2009, 10:09 PM   #7 (permalink)
fatalcore's Avatar
Hi dessibond,
what do u mean my data loss,if u can explain in details it would be very helpfull.I am using 2X500GB, if i increase 1 TB more will it affect my pc's performance? or should i buy a 500GB Seagate external?
regards,
fatalcore
Q9550+GA-EP45-UD3L+4GB CORSAIR DDR2 800FSB+XFX GTS250 1GB+250GB SATA+CORSAIR VX450+CM V8+ASUS XONER D2+SATURN+LGDVDRW+CREATIVE 5.1 INSPIRE+500GBX6 FREE GO AGENT+RAZER MOUSE+DELL LATITUDE 6400.
fatalcore is offline
Old 23-08-2009, 10:14 PM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
@fatalcore, these days, HDD failure rate has increase and that is why I thought it's better to have two 500Gb HDDs as losing 1Tb of data due to crash will be unimaginable.
Old 23-08-2009, 10:22 PM   #9 (permalink)
fatalcore's Avatar
thanks a lot dessibond,
as WD is ur recomendation, then can u kindly suggest 500GB HDD which is stable in terms of performance and money?The Green,Blue and black is confusing in WD website also.I use My Pc for gaming and watching HD Movies.
regards,
Fatalcore.
Old 24-08-2009, 08:00 AM   #10 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Blue: The mainstream 7200rpm HDD
green: power saving features like stop HDD when not in use etc
black: extreme performance for desktops. this one starts at 1Tb and costs 6.5k but is twice as fast as regular HDDs.
- by kool
- by ax3
