Old 19-08-2009, 09:38 PM   #1 (permalink)
clmlbx's Avatar
Question help me to buy Smps & Graphix card ?
budget for both = 5-7k max
smps I guess 500w will be ok .
well how much power will I need for this config...
core2duo 4300 (1.8ghz @ 800mhz)
kingston 2 gb ddr2 (single chip) will buy 1 more (same as I have)
160gb sata2 seagate Hard-disk
Intext tv tuner card without fm
Lg pata dvd writer
one extra fan
+ graphix card that I will buy
mouse keyboard
Motherboard :Intel d946gzis
currentlu using samsung sync master 753dfx,
best resloution 1280 x 1024
well I have 7-8 years cabinet so thought so any good buy with cabinet ..(with very good air flow) currennt procy idle temp is 45 degree celc.
my Mb has 24 pin connector but I have attached my old smps(20 pin),currently I am using very old cabby
Graphics card :- I will be using all 3d, 2d softwares like maya,3d max,photoshop, and much more means lott of use of it. . so what all u recommend.
I asked about graphic card before too but finally I am purchasing now (hope so).
clmlbx is online now
Old 19-08-2009, 10:48 PM   #2 (permalink)
Crowman
Krow's Avatar
Default Re: want to buy Smps & Graphix card ?
Try Seasonic 380W or Corsair CX400W or Tagan TG-500W @ ~3.2k
For GFX youmay have a look at ATI HD 4670 512MB or nVidia 9500GT. Both should suit your budget although I doubt if either will be enough to satisfy your Maya needs. Minimum get 9600GT 512MB GDDR3 @ 5k and the best possible GFX card for you would be Palit GTS250 512MB @ 7.3k although that will be way out of budget.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 20-08-2009, 12:00 AM   #3 (permalink)
clmlbx's Avatar
firstly will 380w enough for my config + gfx
what is minimum I Need (380,400 or 500)
9600gt will not enough for 3d ?
and how is this
cooler master RS500-PCARA3 Extreme Power + 500W ( cheaper then others even in 390 & 460w models )
Posted again:
and how are those zebronics and all that come with 400w smps + cabinet
Posted again:
Old 20-08-2009, 12:32 AM   #4 (permalink)
You'll certainly need a 450 W SMPS minimum 500W will be a better bet. The 9600GT with 512MB DDR3 or Palit's 9800GT 512MB DDR3 card should do for the 3D work it costs Rs. 5700 in Kerala. The SMPS may cost around Rs. 2000.
nmenon is offline
Old 20-08-2009, 10:46 AM   #5 (permalink)
clmlbx's Avatar
what about zebronics cabinet + smps(400W) = 1600-1700 ?
Old 20-08-2009, 10:48 AM   #6 (permalink)
CX400 and HD4670 would be the only combination that would fit your budget. Do not go for Zebby. They are crap!
hell_storm2006 is offline
Old 20-08-2009, 10:06 PM   #7 (permalink)
clmlbx's Avatar
well I am really in budget so want to know If I buy that zebronics 400W smps with cab. will I wrk properley as for last 6-7 years am using local smps and working fine. that will cost me just 1600-1700 so I can spen other for better Graphix card. Just want to know that zebronics 1 will be sufficient for me (my config+graphix card) and it has normal good performance.
what will be the difference between zebronics and corsair 1
Old 21-08-2009, 06:04 PM   #8 (permalink)
I M A *STAR*
saqib_khan's Avatar
They both are much different. Corsair comes with 5 years warranty. You should go for minimum 450 W SMPS. If you go for Corsair VX 450 (available for 4k), then its the best. And for graphic card, I recommend you 4670 and nothing else. These both will cost you around 8k.
Blogging at:
Technostarry
saqib_khan is offline
Old 21-08-2009, 09:57 PM   #9 (permalink)
clmlbx's Avatar
I was looking towards gts 250..........so was thinking of little comprobmising with smps.
actual 500W output (not that local 1 that comes with caby) PSU from zebronics with price of RS 1900.
so wht u guys say pls reply ...urgently neded
Old 21-08-2009, 11:37 PM   #10 (permalink)
clmlbx's Avatar
How is 9800gt+ (1Gb ddr3) ?
Old 21-08-2009, 11:52 PM   #11 (permalink)
clmlbx's Avatar
9800gt or gts 250 both will get into my MB(Intel D946gzis )
and into my old 17 inch crt
Old 22-08-2009, 12:14 AM   #12 (permalink)
I M A *STAR*
saqib_khan's Avatar
Instead of gts 250 , I recommend 9800 GT, as it is more VFM. For now you can go for Zebronics Pro 500 W also. Go ahead , its a good combination.
Blogging at:
Technostarry
Old 22-08-2009, 04:59 AM   #13 (permalink)
clmlbx's Avatar
^^ little scan on nvidia site shows My score after gts 250 will be 8300 and after 9800gt it shows 8100 . My current is ust 600.
But I want to confirm will 9800gt+ (1Gb ddr3) satisfy my Needs for all 3D apps. hardware acceleration (for transcoding video & Image precessing) and Hd output . currently willl connect vga to normal 17 inch flat crt but in future will buy LCD.
Old 22-08-2009, 11:14 AM   #14 (permalink)
I M A *STAR*
saqib_khan's Avatar
^^ Yes, it will satisfy your needs. One more thing, buy the 1 GB version and not the 512 MB version.
Blogging at:
Technostarry
Old 22-08-2009, 11:50 AM   #15 (permalink)
15.0 GHz
VarDOS's Avatar
offtopic:
the title for the post is insutiable, It seems u are askin question to others, whether they want 2 buy GFX and SMPS
VarDOS is offline
Old 22-08-2009, 09:11 PM   #16 (permalink)
clmlbx's Avatar
he he
changed the title
Old 23-08-2009, 08:23 AM   #17 (permalink)
clmlbx's Avatar
Sapphire Hd 4850 Rs :7,392.00
is this price quoted correctly
Old 23-08-2009, 11:44 AM   #18 (permalink)
I M A *STAR*
saqib_khan's Avatar
^^ Should be 200-300 bucks less IMO .
Blogging at:
Technostarry
Old 23-08-2009, 12:05 PM   #19 (permalink)
clmlbx's Avatar
I mean
sapphire Hd 4850
gts 250
9800 gtx
all they come in same category performance wise ..right ?
and gtx series goes better then gts250 ...right ? like gtx260
Old 23-08-2009, 01:57 PM   #20 (permalink)
gpu ati HD4850
Aman31 is offline
Old 23-08-2009, 06:25 PM   #21 (permalink)
Originally Posted by clmlbx View Post
I mean
sapphire Hd 4850
gts 250
9800 gtx
GTS 250 = 9800 GTX+ with better optimization
GTX > GTS
bippukt is offline
Old 27-08-2009, 10:03 PM   #22 (permalink)
clmlbx's Avatar
When I have to spend 7-8 k atleast so will wait for dx11 cards (8-10 september)
anyway which 1 will be better in this
9800gtx+ 1Gb or Gts250 512Mb
Hd 4850 can be compared to Gts 250 ..right?
Hd 4870 can be compared to Gtx 260...right?
as Ati cards are cheaper then Nvidia.
Old 28-08-2009, 10:38 AM   #23 (permalink)
One advice, you are thinking of compromising on the PSU.... BIG mistake! You can always compromise on other parts never on a PSU. I think if you are looking at GTS 250 and HD 4850 then i guess CX400 or VX450W wont be a problem! So fix the PSU and then fix the GPU.
- by kool
- by ax3
