Location: I come from the land of WARRIORS, land of 5 rivers, where the alcohol will make your liver quiver!!
Realtek sound driver - Error Code : 0xE0000227
My Laptop Brand Lenovo
It used to work well but 4m sometime ,when i play any song i just hear a beep ,and so i try to reinstall sound driver but it failed to install with this Error Code : 0xE0000227
Almost Every one of my posts contains the word lol. I laughed out loud at everything, even when it's not funny. lol
You didn't specify the model number of your laptop, so I can't be sure, but I expect that your motherboard uses a Realtek audio chip and the problem is caused by the Microsoft UAA driver.
Go to Device Manager, disable UAA and then uninstall it. (You may have to restart after disabling it before you can uninstall it). Then try to install the sound driver again.
