Old 16-08-2009, 02:42 PM   #1 (permalink)
rohit2hell's Avatar
Default Help My Friend..!!!
My friend has following Configuration
AMD Phenom 9500
Asus M3A Green
Sapharire Ati Readeon X1550
Kingston 1X1 Gb Ram(Speed 667)
250 Gb HDD Seagate
Power Supply 450W
Hes having problem while booting his PC..it takes about 15 seconds to start Booting Or sometimes doesnt Boot
Also Sometimes Pc Hangs while doing anything..even while playing Video file
Aftr that Pc Doesnt Boot Easily..
We replaced Motherbord, HDD and Ram under Guarantee period..
HELP HIM
Thanks In Advance...
rohit2hell is offline
Old 16-08-2009, 03:50 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Thumbs up Re: Help My Friend..!!!
How old is his PC?
Why have u not checked the PSU??
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 16-08-2009, 09:17 PM   #3 (permalink)
15.0 GHz
VarDOS's Avatar
Default Re: Help My Friend..!!!
yeah, replace PSU....might be problem wid it
VarDOS is offline
Old 17-08-2009, 12:19 AM   #4 (permalink)
Crowman
Krow's Avatar
Check if there are any driver issues too. Did the problm start after installing fresh drivers for anything? Or any new softwares? The PSU might be faulty too. Check everything.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 26-08-2009, 09:00 AM   #5 (permalink)
rohit2hell's Avatar
he didnt buyied any extra PSU .. hes using the the default PSU given by his Computer dealer with Cabinet... im suggesting him to go for Cooler Master 500W...
He had formmated his windows so many times dat now he can format it with his eyes Closed (LOLZ)..but still the problem continues..
Old 26-08-2009, 09:05 AM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
check the connectors
check CPU and whether fan is properly mounted and check cpu temperatures
check PSU
remove components one after the other. remove HDDs and try to boot then remove optical drive and try to boot and then remove GPU , then the RAM. This may help to find out which one is faulty or not connected properly.
desiibond is offline
Old 26-08-2009, 09:20 AM   #7 (permalink)
rohit2hell's Avatar
I wanna ask that is AMD 9500 and ASUS M3A green is compactible???
or suggest me a more compactible Motherboard as my wendor is saying that your motherbroad might have problm..
any suggestion??
- by kool
- by ax3
