Hi, I bought (as per suggestions here
) a GTS 250 512MB and CoolerMaster Extreme 600W about a month ago and now I am upgrading my system, a 4 year old P4 based. I will mainly use it for gaming and image processing. My current PC can't even give me 100 fps in CS and I won't use my gfx card with it as there is no point to it.
I will keep the following from my current system:
-GTS 250 512 MB
-PSU CM Extreme 600W (contrary to its name, it is just passable, it seems)
-LG 14" LCD display with max resolution@1440X900
-160 GB SATA HDD. I might junk the old 80GB though.
-Logitech keyboard and mouse.
My
budget is
around 20-23k, which should be sufficient, but some additions are possible
Preferences - I prefer Intel but if the price advantage for an AMD is sufficient, I will go for it too. I am thinking of the following:
CPU - I am thinking of going for a Q9550, as it has 12 MB cache and good clock speed. It will be perfect for gaming, but I am not sure of the price. Other Q9000 series porcessors could be opted for if cheaper/necessary.
-A compatible
motherboard. Not sure how much it will cost and if I should go for a cheap one or a better one. NO OVERCLOCKING for me!
-A good but cheap
cabinet without a good PSU.
-4 GB DDR3
RAM, but if necessary (and compatible with a Quad Core mobo), I can settle for a 4GB DDR2 RAM as well.
-A good 500GB
HDD. No point in having a fast system with an old HDD.
If necessary and if budget left, I could also go for:
- A new and cheap
DVD-R drive
- Decent
speakers (1-1.5k only!) (I have a good Philips headphone for my games, BTW
- A
sound card?
BTW, will my PSU be sufficient to run a system like this?
Also, should I wait for some time for the i3/i5 to come out? Will they be cheaper/better than the quad core?
I know that this is a long post, but I don't want to make a mistake with this one. I am regretting buying the CM 600W extreme PSU. All suggestions are welcome. Please feel free to make drastic changes to any of my mentioned preferences
