Old 15-08-2009, 04:51 PM   #1 (permalink)
Arun the Gr8's Avatar
Question Usin LCD Monitor with DVI or HDMI Input as TV
Hey guys,
I have a query. Can i use a LCD Monitor with DVI or HDMI Input as TV?
If YES, How?
New Dell Inspiron 14: Intel Core i3 350 - 2.26 GHz, 2 GB DDR3 1066 MHz RAM, 320 GB 7200 RPM HDD, 512 MB ATI Mobility Radeon HD 4330
Arun the Gr8 is offline
Old 15-08-2009, 08:06 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Usin LCD Monitor with DVI or HDMI Input as TV
yes you can. Just buy external TV Tuner card with VGA output and that should do it.
desiibond is offline
Old 15-08-2009, 11:24 PM   #3 (permalink)
Will it work without a CPU.. I actually need it like a stand-alone TV..
Old 16-08-2009, 07:11 AM   #4 (permalink)
15.0 GHz
VarDOS's Avatar
yeah, external for External TV Tuners you don't need CPU to be ON...so it will work
VarDOS is offline
Old 16-08-2009, 07:39 AM   #5 (permalink)
Om Ma Ni Pä Me Hum
phuchungbhutia's Avatar
Yeah it dont require cpu for that . . I am using frontech external tuner magic box . .
Om Ma Ni Pä Me Hum: (perfection of-)
Om: generosity,- Ma: pure ethics,-Ni: tolerance n patience.- Pä: perseverance,- Me: concentration,-Hum: wisdom... Using Opera Mini Airtel NOP
phuchungbhutia is offline
Old 16-08-2009, 09:50 AM   #6 (permalink)
Does this mean it can perform all the operations of a regular tv tuner?
Old 16-08-2009, 10:05 AM   #7 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Remember. If you pick VGA tuner and you monitor only has DVI, you need to get VGA-DVI converter (VGA-female on oneside and DVI male on the other so that you can connect the tuner to DVI of your LCD.
Old 18-08-2009, 08:41 AM   #8 (permalink)
Tech addict
surinder's Avatar
Please suggest some cheap but worthy stand alone external TV Tuner cards along with prices. DVI output is also welcome if possible under 1K.
surinder is offline
Old 18-08-2009, 09:05 AM   #9 (permalink)
Bond, Desi Bond!
desiibond's Avatar
I think frontech/intex/zebronics ones are avialble under 1k.
- by kool
- by ax3
