Old 14-08-2009, 03:44 PM   #1 (permalink)
I M A *STAR*
saqib_khan's Avatar
Default Which PSU under 3k
Hi all,
Recommend me the best PSU under 3k. It should be under 3k. It should have 6 pin PCI E connector. I m thinking to buy a graphic card therefore. BTW, I wud be buying 4770. So it requires 6 pin power connector, right?
Thnx.
Blogging at:
Technostarry
saqib_khan is offline
Old 14-08-2009, 04:08 PM   #2 (permalink)
naughty boy :) :)
mahesh's Avatar
Default Re: Which PSU under 3k
Corsair Cx400 Or Seasonic S12II 380W
Phenom II 550 BE | GA-MA78GM-US2H | 160 gb + 500 gb hdd | 2 X 2 gb XMS2 | HD 4850 1 GB | 2033 SW | Tagan TG600-U37 | CM 690
mahesh is offline
Old 14-08-2009, 04:25 PM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
yes H4770 requires power through a 6 pin power connector. my suggestion would be to go for atleast a 450W PSU
desiibond is offline
Old 15-08-2009, 01:18 AM   #4 (permalink)
I M A *STAR*
saqib_khan's Avatar
^^ ok, so which one do u recommend ? Should be under 3k.
Blogging at:
Technostarry
Old 15-08-2009, 07:56 AM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
if strictly inside 3k,
Coolermaster eXtreme power 500W for 2.5k
if you can increase to 3.5k:
Coolermaster Real Power Pro 460W: 3.5k
Tagan Stone Rock TG500-U37 500 Watt: 3.7k
Corsair VX450W: 4k
Old 15-08-2009, 04:29 PM   #6 (permalink)
I M A *STAR*
saqib_khan's Avatar
I've read it somewhere that I should stay away from Coolermaster's extreme series.
Will update this thread on Monday after asking abt my choices
Blogging at:
Technostarry
Old 15-08-2009, 06:05 PM   #7 (permalink)
Crowman
Krow's Avatar
Go for Corsair CX400W if your budget limitations are strict, else I'd recommend VX450W minimum. Don't go for Tagan TG500. My friend's brand new one died in a month and when he sent it to tagan, they shipped back after 10 days and still the PSU wasn't working. He's about to get it smtym soon after a total downtime of arnd 21 days. Also, build quality of VX450W is far superior to the TG-500-U37.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 15-08-2009, 07:17 PM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
I don't think 400W is enough for HD4770 and a dual/quad core processor
Old 15-08-2009, 09:00 PM   #9 (permalink)
Crowman
Krow's Avatar
^Then he may go for the VX450W. But is the CX400W not capable of touching around 500W like the VX450W, which goes up to 570W?
Krow is offline
Old 16-08-2009, 12:26 AM   #10 (permalink)
I M A *STAR*
saqib_khan's Avatar
^^ Really? Does VX450 goes upto 570 W ?
Blogging at:
Technostarry
Old 16-08-2009, 12:48 AM   #11 (permalink)
Crowman
Krow's Avatar
^Yup! Max upto 570W!!!
Krow is offline
Old 17-08-2009, 11:06 AM   #12 (permalink)
-anmol-'s Avatar
Buy a Glacialtech GP AL 650 AA,this particular model is very very good,Costs around Rs 4000 in Delhi NP.
-anmol- is offline
Old 17-08-2009, 12:24 PM   #13 (permalink)
Bond, Desi Bond!
desiibond's Avatar
guys, VX450W can reach upto 570W but that doesn't mean that we can make it run at 100% efficiency or higher as that will increase the heat inside and also may cut short it's life. Better stick to the specs that Corsair gives.
Old 17-08-2009, 02:31 PM   #14 (permalink)
VX 450W would be around 4.1K. It would be way out of your budget of 3K. But if you can get this one, then you can atleast have peace of mind. By the way, Corsair is voted best PSU manufacturer by newegg.com!
hell_storm2006 is offline
Old 18-08-2009, 10:32 PM   #15 (permalink)
I M A *STAR*
saqib_khan's Avatar
Guys, how is VIP Gold 500W ? My dealer is insisting me to buy that. So any suggestions ?
Blogging at:
Technostarry
Old 18-08-2009, 10:38 PM   #16 (permalink)
Crowman
Krow's Avatar
VIP is the best local brand, but not 1% of Corsair!
Corsair CX400W is a much better option @ ~3.2k
OR Coolermaster Real Power Pro 460W: 3.5k [much better]
Krow is offline
Old 19-08-2009, 01:07 AM   #17 (permalink)
I M A *STAR*
saqib_khan's Avatar
I think VIP is not a local brand. It s imported by Kunhar peripherals. And do u really think its the best? Does it include PCI E 6 pin power connector?
Blogging at:
Technostarry
Old 19-08-2009, 11:00 AM   #18 (permalink)
Crowman
Krow's Avatar
^That may be, i really don't know.
All I know is that many "babus" with a computer shop have tried to recommend VIP 500W to me. I personally would not buy it even if i had a budget constraint. I would go for CM eXtreme Power series. Thing is that I don't trust these VIP/Zebby/cheapo brand.
VIP is everybody's recommendation and hence appears to be either the best of the cheapo ones or a very good marketing ploy.
Krow is offline
Old 19-08-2009, 11:23 AM   #19 (permalink)
naughty boy :) :)
mahesh's Avatar
wat abt Zebronics PRO-500------2850/-
mahesh is offline
Old 19-08-2009, 11:49 AM   #20 (permalink)
Bond, Desi Bond!
desiibond's Avatar
I think zeb pro-500 is a decent product, given that it comes with a 3yr warranty but am sceptical about it's stability when your system touches 400W+ output and also about the service and RMA.
CM extremepower 600W too faces issues when the load goes beyond 450W
- by kool
- by ax3
