Old 10-08-2009, 02:50 PM   #1 (permalink)
zbuu's Avatar
Cool Plz suggest best mobo (intel Chipset) under Rs 7000.
hi guys Plz suggest best mobo (intel Chipset) under Rs 7000(max).
zbuu is offline
Old 10-08-2009, 02:55 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Plz suggest best mobo (intel Chipset) under Rs 7000.
is that with onboard GPU or without onboard GPU?
There are couple of P45 based mobos from Gigabyte and ASUS that are pretty solid but these are without GPU.
desiibond is offline
Old 10-08-2009, 06:57 PM   #3 (permalink)
well i've been banging my head over this same topic since yesterday.
thinking of going for this. just under 7k @itwares
http://www.giga-byte.com/Products/Mo...e=GA-EP45-UD3L
maldyzooks is offline
Old 10-08-2009, 07:56 PM   #4 (permalink)
Similar threads on the same page???
Suugest a pc config for Rs 60000
hell_storm2006 is offline
Old 10-08-2009, 10:59 PM   #5 (permalink)
zbuu's Avatar
no need for on board gfx card. btw this mbd is for me not for my friend.
which one the following is better:
Msi P45 NEo 3 Fr
Gigabyte UD3L
Msi P43 Neo FR
or
MSI P45T-C51 (http://msi.com/index.php?func=prodde...0&prod_no=1838)
im really confused plz help me out?
zbuu is offline
Old 10-08-2009, 11:08 PM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
my pick would be Gigabyte and check this:
http://www.giga-byte.com/Products/Mo...ProductID=2937
1. Ultra Durable 3 technology with 2 oz copper PCB for lower working temperature
2. Revolution energy saving design with DES Advanced featuring hardware based Dynamic 6-Gear switching
3. Supports 45nm Intel Core 2 multi-core processors with FSB 1600 MHz
4. Natively support dual channel DDR3 2200+ for remarkable system performance
5. Ultimate graphics performance with PCI-E x16 interface
6. 100% 50,000 hours lifespan of Japanese solid capacitors design
7. Patented DualBIOS with dual hardware BIOS protection
8. Hardware Overvoltage Control IC provides more voltage control options on CPU, North bridge and memory
9. Blu-ray playback supported by Blu-ray playback supported by high quality 106dB SNR ALC889A HD audio
Old 10-08-2009, 11:17 PM   #7 (permalink)
Do not go for MSI. They have bad capacitors. BIOS is not that good. Also am sure you would get heating problems!
Old 11-08-2009, 07:40 AM   #8 (permalink)
zbuu's Avatar
@desibond the ud3r looks awsm. but will it fit in to my budget(rs 7000)?
zbuu is offline
Old 11-08-2009, 08:53 AM   #9 (permalink)
Bond, Desi Bond!
desiibond's Avatar
It should, given that it's doesn't have CF and CF based P45 mobos start at 8k price range. I think it retails for 105$ in USA.
Old 11-08-2009, 04:55 PM   #10 (permalink)
zbuu's Avatar
it costs above 8k. hw the gigaybte ep 45 ud3l mobo?
zbuu is offline
Old 11-08-2009, 05:18 PM   #11 (permalink)
Bond, Desi Bond!
desiibond's Avatar
you can go for that one too. And I liked that space left between PCI-E slot and PCI slot. helps if you want to add a dual slot GPU and two PCI cards.
Old 11-08-2009, 05:31 PM   #12 (permalink)
zbuu's Avatar
wat about Msi P45 neo 3 FR . i think itz got better cooling.
zbuu is offline
Old 11-08-2009, 05:48 PM   #13 (permalink)
Bond, Desi Bond!
desiibond's Avatar
MSI P45Neo3-FR is a superb board. But somewhere deep in my mind, I have a feeling that Gigabyte and ASUS are more safer in terms of longevity and support.
If you have not such feeling, definitely you can go for it. Let others too respond as to how they feel about this board.
Old 19-08-2009, 08:52 AM   #14 (permalink)
zbuu's Avatar
Smile Re: Plz suggest best mobo (intel Chipset) under Rs 7000.
thanks to all of u 4 ur support
ok i have decided to go 4 da gigabyte board. Could u tell me where can i buy gigabyte mobos from bangalore. plz include tel no if possible.
zbuu is offline
Old 19-08-2009, 08:59 AM   #15 (permalink)
Bond, Desi Bond!
desiibond's Avatar
SP Road
sagar
Golcha
Ankit
these three are places in SP road where I usually search
Old 19-08-2009, 10:17 AM   #16 (permalink)
Super Moderator
asingh's Avatar
Could you show me a few links supporting the same...
1. Bad BIOS -- most motherboards out of the box need a BIOS flash which corrects things.
2. Capacitors -- mostly solid state these days. Have long life span. Obviously a component will go 'bad' if not treated correctly. Bad voltage, incorrect configuration.
3. Heating -- depends how the system has been physically set up. Have seen boards with good cool pipe solutions.
Do not come in here and make comments of the bat.
ASUS, Gigabyte, MSI, EVGA, FoxConn are all companies famous for making excellent boards -- infact that is their main product.
asingh is offline
Old 19-08-2009, 10:39 AM   #17 (permalink)
guys suggest me good IGP(AMD/intel both) mobo...
wud hav gone for same mobo as ZBUU has gone for..need a mobo upgrade too
but was lookin fr grafix solution as well ..dont feel like investing in gfx card ryt nw..
budget is 10k at the max..
currently hav pentium E2400 currntly ..wont mind switching to amd if i get good bang for the buck!!!
JaAcE is offline
Old 19-08-2009, 11:05 AM   #18 (permalink)
zbuu's Avatar
Originally Posted by desiibond View Post
SP Road
sagar
Golcha
Ankit
thanks could u post their respe\ctieve phone nos too plzzzzzzz
zbuu is offline
- by kool
- by ax3
