Yes, you heard it right. Day before yesterday,i was working in my system, while at that time i opened around six applications say eclipse,media player,a mysql server, photoshop and dreamweaver 8. After a few hours, when i press the Build button in eclipse it hangs. So i just re-boot the system by pressing the reset button. And after that while booting, the windows xp loading screen appears and again restarts.
The only solution to this problem is to re-install the OS. The same happened yesterday night too. So i just re-installed the OS and man its really f(king hard to find what's wrong with my PC.
So please tell me whats the posible cause for the frequent system crash.
My PC config is :
E6600@3GHz(Does the OC affect the PC in anyway)
ASUS P5N-MX
2GB DDR2
Zebby 450W PSU
WD 320GB AAKS(This one has some damaged disk space of around 10GB,will it affect the PC by any means)
guys i need ur help so that i myself avoid from re-installing the OS in near feature.Cause it badly affect my job....
