Old 08-08-2009, 02:06 AM   #1 (permalink)
Crowman
Krow's Avatar
Default "Standalone DVD player" which works like VLC?
I'm planning to buy a standalone DVD player. I need :
DVD playback
MP3 playback
FM Tuner
Audio CD playback
Data DVD playback (Backed up movies in DVD's using Nero>Make Data DVD) -> The movies I need to play are in avi/mp4 format, ripped from original DVD's, newhr between 700MB - 1.6GB.
Please recommend good DVD players with all the above features. The last feature is what i'm really looking at. Budget is not large (3k-5k), but if i find all the features, I may just dig deep into my pockets.
PS - I know ConvertXtoDVD will work for me, but just need a player to play my already backed up movies.
Also I need a good 5.1/7.1 speaker setup for around 5k for the above mentioned player.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 08-08-2009, 10:18 AM   #2 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
Default Re: "Standalone DVD player" which works like VLC?
the dvd players with usb drive can easily play Divx/Xvid movies . i doubt about fm tuner btw .
and all players can go audio and video DVD discs
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 08-08-2009, 11:58 AM   #3 (permalink)
Crowman
Krow's Avatar
Thanks, but can u post a good brand for DVD players. Also, which speaker setup would u recommend for arnd 5k?
Krow is offline
Old 08-08-2009, 01:29 PM   #4 (permalink)
Samsung p480r it comes for 3K it has fm,usb. Hope this helps
MSR@THNIK is offline
Old 09-08-2009, 12:44 PM   #5 (permalink)
Crowman
Krow's Avatar
^Point taken. Thanks. I'll scour the market soon.
Krow is offline
Old 09-08-2009, 06:12 PM   #6 (permalink)
Crowman
Krow's Avatar
I found Sony NS-628 to be a good featureful DVD player @ 3.3k
Plays DivX movies even from USB
Can ne1 suggest a better DVD player (budget upto 5k)??
Krow is offline
Old 10-08-2009, 02:33 AM   #7 (permalink)
Point Blanc
check out philips models, will see which one and tell later. Also LG ones, sony as usualy may miss out some features,
and best to do a lookup is this siteCompare India
this will give a little insight
acewin is offline
Old 10-08-2009, 02:46 AM   #8 (permalink)
Point Blanc
something which I was expecting really Philips and Samsung are in the best ones.
check out Samsung p480r,
in 5K u will get players with HDMI out and supporting HD playback
acewin is offline
Old 10-08-2009, 10:57 AM   #9 (permalink)
Crowman
Krow's Avatar
I found the SAMSUNG P490R for about 3.5k, but i dnt think it supported playing movies from USB. Can u please explain what advantage does HDMI out have? Also, HD playback means it plays HD avi, right? Is there a player which will play an HD rip(1080p) like the trailers in the Digit DVD and also full movies(6GB)?
Krow is offline
Old 12-08-2009, 03:51 PM   #10 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
I am not sure about availability , but find a player with x264 support, if you can .
jin files ka koi server nahi hota unka bittorrent hota hai
chesss is offline
Old 15-08-2009, 11:09 AM   #11 (permalink)
Crowman
Krow's Avatar
^x264 doesn't look available. Would hav been good to have it though.
Anyway, I shortlisted possible candidates for my player, thanks to acewin.
Compare India - DVD Players - Philips-DVP5996K/94
Compare India - DVD Players - Philips-DVP 3996
Compare India - DVD Players - Samsung-DVD-1080PK
Compare India - DVD Players - LG-DV 388
Compare India - DVD Players - Philips-DVP 6565
Compare India - DVD Players - LG-DN 192H
The budget is 5k max. Which one should I go for? The 5.1 speakers are going to be Logitech X-540 to accompany the player. Thanks in advance to all those who help and also to those who already have.
Krow is offline
Old 16-08-2009, 11:44 PM   #12 (permalink)
RPG FTW!!!
Techn0crat's Avatar
As you will also be playing data DVDs,most DVD players don't even show data if it is written in 2nd or 3rd session.They will only show data written in 1st session.and also check for codec compatibility such as Divx,xvid and MPEG4 while ripping in .avi format.
The truth is out there...anybody got the URL?
Techn0crat is offline
- by kool
- by ax3
