Old 07-08-2009, 02:16 PM   #1 (permalink)
Red face Sharing Internet help needed
I got no idea about networking , i think this might be a silly doubt .
What i got
Running 2 pc with win xp sp2 which already has a network
Local area connection ->
Pc 1 (where i need internet to be shared)
Ip address 192.168.0.1
subnet mask 255.255.255.0
pc 2 (where i have a usb modem connected)
Ip address 192.168.0.2
this pc also have a local area connection 3-> with obtain ip automatically
What should i do to share internet connection to pc 1 , i have it only on pc 2
Please help
Thanks
www.LiveGlamour.com
eureca_eureca is offline
Old 09-08-2009, 01:14 PM   #2 (permalink)
CpyderGraphix
cpyder's Avatar
Default Re: Sharing Internet help needed
on pc connected with internet (in your case PC-2)
go to network connections - properties - sharing tab - check sharing on and then select the LAN connection to share it with.
Now at this point, the OS might do something on its own, like assigning network address etc.
Now connect a 'CROSSOVER' lan cable between two computers. The usual patch cord is parellel one and will not function. You will have to get one made.
In the PC 1, keep the network address to automatic.
Shutdown both PCs, start the one with internet first and then the client one.
See if it works. If it does not.. in the Internet computer assign network address as 192.168.0.1, Subnet Mask 255.255.255.0, rest- leave blank.
in the client computer, assign network address 192.168.0.2, Subnet Mask 255.255.255.0, gateway 192.168.0.1 (note this is the address of PC1), DNS 4.2.2.1 and 4.2.2.2 (or you can use whichever DNS address)
Check firewall settings to allow traffic through this.
Follow the restart procedure.
You should be on..
See you at anditworkedforme.com
cpyder is offline
Old 09-08-2009, 11:25 PM   #3 (permalink)
Point Blanc
right, you will need a crossover cable, otherwise buy a cheap network switch.
But before that, which model you got check the model number.
I think you will have a RJ-45 port in the modem, in that case you will just need normal lan cable which is also called RJ45 cable
acewin is offline
Old 10-08-2009, 12:53 AM   #4 (permalink)
I am connected with usb from modem to comp ,
Cpyder ill try it tomorrow and tell u the results
Posted again:
www.LiveGlamour.com
Last edited by eureca_eureca; 10-08-2009 at 12:57 AM. Reason: Automerged Doublepost
Old 10-08-2009, 02:30 AM   #5 (permalink)
Point Blanc
buddy, I asked which modem, make, company
acewin is offline
Old 10-08-2009, 11:51 AM   #6 (permalink)
SmartAx MT882 , my old bsnl bb modem
www.LiveGlamour.com
- by kool
- by ax3
