Old 04-08-2009, 02:54 AM   #1 (permalink)
Cool G5's Avatar
Default Connect MTNL Broadband on laptop
I need to configure MTNL triband on my Dell Inspiron 15 laptop. I had earlier configured the modem already so I think I need not to do so again. I'm on Vista Home Premium which I can't navigate with ease due to non-use.
I will be checking the replies here from mobile so it would be better if you jot down the process here instead of pasting any link.
Cool G5 is offline
Old 04-08-2009, 07:16 PM   #2 (permalink)
haider_up32's Avatar
Default Re: Connect MTNL Broadband on laptop
u just need to plug in the cable and start using if DHCP has been configured in modem
The new digIT forum with all those adds sucks!!! Learn some adsense.
haider_up32 is offline
Old 08-08-2009, 12:16 AM   #3 (permalink)
Cool G5's Avatar
Problem Solved : The laptop had some difficulties getting connected via LAN port so I connected via USB & its working fine.
Cool G5 is offline
- by kool
- by ax3
