Old 03-08-2009, 02:57 PM   #1 (permalink)
Question Logic behind disabled cores?
Hello guys. I recently read reviews of some triple and dual core processors from AMD. some of them (Mostly triple core processors) are quad cores with one or two cores disabled.
So, my question is why do they disable those cores? Just to avoid an architecture change or is it a part of manufacturing process to use the faulty chips?
Rishi87 is offline
Old 03-08-2009, 09:56 PM   #2 (permalink)
Default Re: Logic behind disabled cores?
I'm not 100% sure, but I believe they're making good use of imperfect cores, that is, quad cores in which one core is defective.
Actually, this is a clever idea. Many CPUs (whether single core or multiple core) are made at the same time from a single silicon wafer, but manufacturing CPUs is such a difficult process that a large percentage comes out defective. Some of the defective units can be repaired with laser trimmers, but some have to be rejected.
With multiple cores, one core may be defective while the others are perfectly OK. Marketing those with the defective core disabled is a good idea.
pimpom is offline
Old 04-08-2009, 10:30 AM   #3 (permalink)
And certain batches of those CPUs with one or two cores found defective aren’t actually defective. Sometimes due to higher demand for these processors, those cores are deliberately disabled and sold at a lower price. If you’re one of those lucky few who manages to get hold of this batch of CPUs then you can unlock the other cores and get more bang for your buck. Although, you may void warranty in doing so, most such procs work just fine.
otpsurvive is offline
Old 04-08-2009, 11:42 AM   #4 (permalink)
So, are there Intel processors also with such disabled cores?
Rishi87 is offline
Old 04-08-2009, 11:44 AM   #5 (permalink)
Wire muncher!
infra_red_dude's Avatar
1) To save on fabrication costs. The company doesn't need to send more than 1 mask to the fab (which is exorbitantly costly).
2) To make use of defective dies (one core maybe defective, so instead of throwing away the whole die, they are marketed as a lower end version).
infra_red_dude is offline
Old 04-08-2009, 11:44 AM   #6 (permalink)
Super Moderator
asingh's Avatar
So if someone unlocks a defective one..what happens..??
asingh is offline
Old 04-08-2009, 11:58 AM   #7 (permalink)
Check this article on Tom's Hardware.
http://www.tomshardware.com/reviews/...m-ii,2273.html
Rishi87 is offline
Old 04-08-2009, 08:11 PM   #8 (permalink)
Wire muncher!
If its the 1) case from my post then you are in for trouble as you will haf stability issues.
If the reason for disabling was 2) then you haf a core for free!
Old 05-08-2009, 12:21 AM   #9 (permalink)
Hey, IRD: aren't you a bit mixed up about your own post? You interchanged 1) and 2) in this post.
pimpom is offline
Old 05-08-2009, 01:51 AM   #10 (permalink)
Wire muncher!
^^^ Lol.. yeah...typo.. 1) is 2) and vice versa
- by kool
- by ax3
