Old 28-07-2009, 09:08 PM   #1 (permalink)
Default New Rig Help!!!
ok so i orignally planned to get this rig:1.Asus P5Q-Deluxe-14,500
2.Intel E8400-8,100
3.Thermaltake Ultra 120-3,000
4.CM elite 330-3,900.
But the problem is this is working out to around 30k! which is a bit much for me so i wanted to know if you can suggest a rig for the similar performance but less price
rohan-04 is offline
Old 28-07-2009, 10:25 PM   #2 (permalink)
harryneopotter's Avatar
Default Re: New Rig Help!!!
I am assuming that u will be taking a GPU also beyond tht budget coz the motherboard u specified dsnt have onbaord graphics.
here is a much better config :
Phenom II X4 940 -- 10300
Jetway Hummer H07 -- 7 k
TRUE -- 3k
Coolermaster CM690 -- 4.5 k
total around 25 k. Wayyyyy much better than the previous combo in every department.
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
harryneopotter is offline
Old 28-07-2009, 10:28 PM   #3 (permalink)
naughty boy :) :)
mahesh's Avatar
phenom II 550 BE
MSI 790GX-G65
Corsair DDR 3 TWIN3X2048-1333C9
CM Elite 330
Phenom II 550 BE | GA-MA78GM-US2H | 160 gb + 500 gb hdd | 2 X 2 gb XMS2 | HD 4850 1 GB | 2033 SW | Tagan TG600-U37 | CM 690
mahesh is offline
Old 28-07-2009, 11:39 PM   #4 (permalink)
A,graphics card i have (9600GT superclocker).Hmmm never really considered Amd but i will now,also can you tell me a config Processor and mobo 15k and the rest i will get later.I am also going to want to overclock.
rohan-04 is offline
Old 28-07-2009, 11:45 PM   #5 (permalink)
Also will DDR 2 Memory work in a DDR 3 slot or will i need to get those also?
rohan-04 is offline
Old 29-07-2009, 12:01 AM   #6 (permalink)
for 15 k
Phenom II X4 940 - 10300
Biostar TA 790GXBE - 4.6k
Best u can get, A Powerful Quad Core which shines in Gaming too. And A Great chipset base mobo.
Y ??
Old 29-07-2009, 12:04 AM   #7 (permalink)
No, they wont!!
Y ??
Old 29-07-2009, 01:03 AM   #8 (permalink)
Ok insted of getting a quad core,what about AMD II X3 720BE?? how will that perform with the MSI 790GX-G65???
rohan-04 is offline
Old 29-07-2009, 01:15 AM   #9 (permalink)
thts a good choice, but for tht mobo u'll need DDR3 ram. If u want thn i have a Biostar 790Gx board with Phenom II 720 bought yesterdy, un used. If u say thn u can have good deal only if u can settle for tht combo.
Otherwise i will recommend to go for a Quad core if u have the budget for tht.
Y ??
Old 29-07-2009, 01:19 AM   #10 (permalink)
Hey yeah why dont you pm me???
I am really interested.
Btw where do you stay?
rohan-04 is offline
Old 29-07-2009, 01:20 AM   #11 (permalink)
rohan-04 is offline
- by kool
- by ax3
