Old 26-07-2009, 02:50 AM   #1 (permalink)
hskpunjabi's Avatar
Question Intel Mobo/chipset+processor combo
hi friends,could u pls suggest some good chipset ( preferable intel)+ processor combo (like core 2 duo) with price range,,,,,
n onboard graphics more than or equal to 256 mb are welcomed.
or a good mobo+processor+gfx card for mid range gaming (could play cod series)
what about intel G45,41 etc chipsets !!
hskpunjabi is offline
Old 26-07-2009, 10:44 AM   #2 (permalink)
Default Re: Intel Mobo/chipset+processor combo
Posted 8 hrs back and still no reply .... So much for the Intel Cores..
Mate, you gotta mention your budget first - then ask for suggestion! So that it'll be easy for us to tell the recommendation apt for the budget.
Gigabyte - EG43M-S2H - 5350 PLUS E7500 - 5670 (FYI, AMD X4 9650 @ jus 6050 performs better than this)
ABIT IP35/ P45 Neo3-FR V2 - 6825 PLUS E8400 - 8,815 (OR) Q8400 - 8950 (FYI, AMD's X4 810 @ 8350 performs better than E8400) PLUS PALIT 9600GT(512)/8600GT(256mb)
P45 Neo3-FR V2 - 6825 PLUS Q9550 - 11,787 PLUS PALIT 9600GT (512) / 8600GT (256)
Note the last two mobo has no integrated graphic processor - so u need a video card to get the display to monitor.
If you browse through the internet you'll get lots of recommendation for AMD - that's because they perform equally good as INTEL or better than INTEL at a little lower price.
But I'd personally go for INTEL just like you.
One more thing - Difference between dual cores and quad cores (both AMD 'n' INTEL)
DUAL cores have higher clock speed (>2.6) and performs better in games and other applications that doesn't make use of 4 cores completely or efficiently)
QUAD cores have little lower clock speed and performs way better than DUAL cores if the apps make use 4 cores.
Intel D930&945GNTL| 2x1GB 667 Mhz(Transcend+Kingston)| 500GBSeagate+200 GB WD|Zotac 9600GT Amp!| Zebronics Platinum 400W|Dell SP2208WFP|Logitech z5500| Lite-onDVD-RW+LGDVD-R
emmarbee is offline
- by kool
- by ax3
