Old 25-07-2009, 03:47 PM   #1 (permalink)
Wandering around
Default TV Tuner card (Internal ONLY)
Hi all
I am currently considering buying an Internal TV tuner card that would go with set top box/ dish TV. Since I have never watched tv on my computer, so I have very Little Idea about the issue. While searching on the net for reviewes some things intrigued me...
1. Whats the difference between pci and pcie cards (Apart from slots plz.... in picture quality)
2. Currently all services are analogue..... but dual HDTV/Analogue cards are also available from Avermedia..... What should be better....(digital cards cost >4k)?
3. Whats the funda of satelite TV cards?
4. What to buy.....?
Will be buying next week ... plz help guys.
Shadowfax2009 is offline
Old 25-07-2009, 08:04 PM   #2 (permalink)
15.0 GHz
VarDOS's Avatar
Default Re: TV Tuner card (Internal ONLY)
to connect DishTV to PC, i used a Pixel View P4500 Card,
here is the tutorial how to attach it to PC
Visit : http://askvarad.blogspot.com/2009/06...htv-to-pc.html
VarDOS is offline
Old 26-07-2009, 02:30 AM   #3 (permalink)
Wandering around
Thanks
Old 26-07-2009, 10:54 AM   #4 (permalink)
Actually I shouldn't be replying in this topic, as I had no idea about TV tuner cards a day before. But recently I had made a search on good tv tuner cards in the market. So I may give u some tips.
1) Probably there won't be any difference in quality - if there aren't any difference in SPECS of both cards.
2)GO FOR ANALOG ONLY - HDTV WONT COME TO INDIA ANYTIME SOONER. But if the DIGITAL TUNER cards has better softwares/hardware for encoding the video (capturing or recording), you can go for it. As you might get a better quality in viewing and capturing tv.
3)pass
4) If you can get hauppauge tv tuner cards, then go for it. Else wait for other members suggestions.
Intel D930&945GNTL| 2x1GB 667 Mhz(Transcend+Kingston)| 500GBSeagate+200 GB WD|Zotac 9600GT Amp!| Zebronics Platinum 400W|Dell SP2208WFP|Logitech z5500| Lite-onDVD-RW+LGDVD-R
emmarbee is offline
Old 26-07-2009, 03:28 PM   #5 (permalink)
I also suggest hauppauge
MasalaStation.com
myhotdog is offline
Old 27-07-2009, 08:56 PM   #6 (permalink)
Wandering around
Thanks all... Ill put back the findigs of my searches later.
Old 28-07-2009, 04:11 PM   #7 (permalink)
I M A *STAR*
saqib_khan's Avatar
I m using PixelView Play TV Pro 3 with my DishTV. Fully satisfied with it. It has Radio, timeshift, record, etc features. Overall very nice.
Blogging at:
Technostarry
saqib_khan is offline
- by kool
- by ax3
