How to recover BIOS after BIOS update failure??
http://www.biostar.com.tw/app/en-us/...aq.php?S_ID=81
I tried to reflash the bios
While Updating the BIOS with the BIOS update windows utility the Programme hanged and i have to restart it (after atleast 6-8min) now
I am having trouble booting the PC (No display see more infomation for more detailed)
Kindly help...
There is a Problem with the BIOS... I tried the method of AMIBOOT.ROM but it didn't worked
Please forward a procedure by which i can reflash the dead bios...
MORE INFORMATION
I have a backup of the original Bios on D:
Actually when i tried to format the UTILITY hanged and the system was stuck (no mouse was moving etc)
and because of that i am not able to boot anymore...
LED_D1 ON
LED_D2 OFF
CD METHOD
cd rom light ON (IT doesn't turn off) so i think it might be searching bios file on the cd so i tried that and put AMIBIOS.ROM and booted nothing pressed ctrl+home nothing, made different cd with AMIBOOT.ROM and booted nothing, pressed ctrl+home nothing... so cd method is not working
Motherboard Speaker
Motherboard speaker NO response to dead bios (i tried to remove ram and check and it was beeping when i removed the ram so the speakers are okay)
Tried to connect Floppy drive But no Power Led activity ( i check inserting the floppy and than keep pressing CTRL+HOME didn't worked either)
USB thumb drive followed this procedure
1 - Copy the BIOS file to root of a USB stick as AMIBIOS.ROM (all UPPER case).
2 - Start with power off on the target machine.
3 - Insert the USB stick.
4 - Hold down the Ctrl and Home keys and turn on power.
5 - Watch for the USB stick light to blink, and immediately release the keys.
This may take approximately 15 to 20 seconds.
6 - The display will come to life with the AMI BIOS Recovery utility, and will
report it's progress (with periods ....).
7 - The completion status will be reported at the conclusion, and the machine will
automatically be rebooted.
8 - If it was successful, you'll see the BIOS POST screen. Hit the DEL key and
enter the BIOS setup. Set "Optimized Defaults". Save and exit.
I tried to press CTRL + HOME still no light lit on the USB (no activity on the usb drive)
Tried CMOS reset and Battery discharge but didn't worked either
Kindly help
