Old 23-07-2009, 05:33 AM   #1 (permalink)
Default Cool 'n' Quiet - Phenom 2 X4 920
Hi,
I cant get the Cool N Quiet working on my M3A78-EM with my Phenom 2 X4 - 920. I have Cool N quiet turned on BIOS. The speed is steady at 2800 when i tested using Cool N Quiet Application from ASUS and CPU-Z as well.
I am on the latest BIOS version. Any suggestions please...
PROC: AMD X2 7750 BE, MoBo: Gigabyte M57SLI-S4 , Ram: 2*1GB 800 MHZ PC 6400,Cooler Master 500W SMPS, HD 1TB WD, 500 GB Seagate,2* 250GB, 160 GB,19" TFT,Logitech MX3200.
popularbhaskar is offline
Old 23-07-2009, 08:16 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Cool 'n' Quiet - Phenom 2 X4 920
http://www.amd.com/us/Documents/Cool...ion_Guide3.pdf
a bit old but a good doc.
desiibond is offline
Old 23-07-2009, 10:20 AM   #3 (permalink)
dOm1naTOr's Avatar
i think PC probe 2 can enable it on OS
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 24-07-2009, 12:20 AM   #4 (permalink)
Thanks a lot guys. Let me admit.. i was a dumbo about this part. I did not know that i had to change the power scheme to max battery for this to work. I did change that and its working. so.. its all good.
-Bhaskar
Old 24-07-2009, 12:22 AM   #5 (permalink)
Admins.. plz close the thread.
- by kool
- by ax3
