22-07-2009, 11:25 AM
Excessive happiness
RAM Issues
I am having a weird problem. When i install application it get installed, no problem here. But when i try to run it, it wont show up and working, it disappears. The cursor appears to be busy for few minutes and then everything is normal. Application doesn't get opened. I opened the Task Manager and see the processes list, what a surprise the process is still roam around there. It moves up and down, randomly.
This happens when every time i open a application like VLC Media Player, Dreamweaver or whatever application i installed in my PC.
So i thought the problem is with the Memory. So i ran the MemTest application, and it shows around 4 errors that the xxxxxx to xxyyyy memory is corrupted.
My question is Windows Media Player and some kinda applications work best, but few of them i mentioned earlier failed to work. What does that mean? Does the RAM went kaput or the RAM Slot?. I hope not. Coz rest of applications works good. Please help me regarding this problem..
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
Reason: Editing the title
22-07-2009, 03:43 PM
99.9% Idle
Re: RAM Issues
You cannot trust an application just by saying that it has found some errors. And its also not easy as anything like the RAM gets corrupted after some days. If it could load windows it has to run the apps as well. Just my observation is that you need to revive your system for malwares which has got the probability to do all these kinda strange things.
Unban praka123
22-07-2009, 04:20 PM
mortal kombat
Re: RAM Issues
your rams seems to be perfectly ok faulty rams will show error in even windows loading like mentioned in the afore post.or it would crash your windows.
22-07-2009, 05:08 PM
Excessive happiness
Re: RAM Issues
^^ OK Guys. Then i do scan my system using my KAV2009 and then come here if i still have any issues.
BTW If the RAM is not faulty, then why do the MemTest says so. Will i trust the application? Please clear me.
Cause i already had a Transcend 2GB DDR2 JETRAM which was sent to RMA and waiting for replacement. I dont want to change my RAM now and then.
PS Request
22-07-2009, 08:28 PM
Super Moderator
Re: RAM Issues
This hardly sounds like a RAM issue. To early to say. Do not jump the gun..
Do the following systematically:
1. Do a system restore to a point when your system was working correct and check.
2. Do a full system scan (all files/deep registry).
3. Run Spyware/Spybot.
This same thing happened to me once. I did a system restore and it was fine. High chance this is a Windows Explorer error -- cause you see the application in the task manager, so it is successfully getting addressed to a RAM location. The process will jump rank on the task manager cause its memory location is changing and so is the CPU cycle time.
Also it would be helpful, if you could tell your system setup.
23-07-2009, 03:29 PM
Excessive happiness
Re: RAM Issues
1 . I did the restore and it works OK, and i install VLC. gosh, the same problem. The process jump rank in task Manager and still not show up.
2 . Unable to install KAV 2009 as the setup file instead do the same as VLC.
3 . Found few Spywares and deleted them.
It seems to be the virus may be the suspect as the games working perfectly normal.
Now my question is,
Do a full format helps me get rid of this.
I got a lot of files there backed up and dont wanna loose them. So i just write them to DVD, full format the system and install a fresh copy of OS and a AV program and then copy the backup from DVD, and scan them. Does it seems a good idea?
My setup is
E6600 @ 2.8GHz
2GB DDR2 Dynet RAM (Using this as my Transcend RAM sent for RMA)
ASUS P5N-MX
Zebronics 450W SATA-II
WD 320GB AAKS
PS Request
23-07-2009, 10:48 PM
Super Moderator
Re: RAM Issues
Now my question is,
My setup is
E6600 @ 2.8GHz
ASUS P5N-MX
WD 320GB AAKS
Yes..this is fine..go ahead..!
23-07-2009, 11:42 PM
Simply a DIGITian
Re: RAM Issues
Hey I was facing the same prblm some time ago. When scanned onl9 found some viruses. Aftr removing thn everythng got fixed. Even I thought ths of a RAM issue @ first time.
I'll say scan ur pc onl9..........b4 formatting
- Read The Forum RULES First.
- Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
- Before Starting A New Thread Read The STICKY THREADS First
- Before Participating In Bazaar Section Read The BAZAAR RULES
24-07-2009, 12:13 PM
Excessive happiness
Re: RAM Issues
^^Thanks dude.
Finally i think i found the culprit. Whenever i open the Task Manager, i see a process named notepad.exe running there. But in fact, i didn't open any application, say even a notepad.
What's this all about? Is this the virus that we are talking about?
PS Request
24-07-2009, 01:02 PM
Simply a DIGITian
Re: RAM Issues
yes dude......me 2......
Tat time I also found numbers of notepad.exe thr......eating up my bandwidth........even my net got slower.....
aftr a onl9 virus scan It's all running f9........
24-07-2009, 02:33 PM
Excessive happiness
Re: RAM Issues
Gosh, its hard to read ur english. Anyway what AV program do u use to scan at that time. Coz my KAV doesn't even get installed. So i need a free AV. Please suggest me one.
PS Request
24-07-2009, 02:46 PM
Re: RAM Issues
It may be possible that virus is not allowing KAV20009 to get installed.
Use symantec/norton anti-virus to scan your PC.
If that also fails, then don't waste your time & just backup the data, do complete format & reinstall OS.
24-07-2009, 02:48 PM
Excessive happiness
Re: RAM Issues
Will do that dude.. I'm currently in Office...
PS Request
24-07-2009, 06:25 PM
Simply a DIGITian
Re: RAM Issues
I use KIS2009
I said run an onl9 scan.........I used kaspersky onl9 scanner @ tat time......
If u r on a limited plan then dnt waste time just do a total format.......
Aftr tat u'll b able 2 install KAV. For nw its is the virus tat is nt allowing u 2 install KAV.
Well sorry for my bad english.......!! Plz manage it....!!
24-07-2009, 11:22 PM
Super Moderator
Re: RAM Issues
Originally Posted by krishnandu.sarkar
I use KIS2009
guys.....man..you..really like to HIT the panic button..gosh...!
Send RAM for RMA, clean format. This is like the last thing you should do -- > clean format. Specially for a virus.
I googled your problem for 20 seconds..believe me..and got this.
25-07-2009, 02:18 PM
Excessive happiness
Re: RAM Issues
Thanks a lot for the info dude. I'll try the idea they gave in the site and see whether it works for me. I re-installed the OS yesterday and still had the same problem. As i am short of time to take backup(important backup's around some 50GB). So will try to do it by Sunday and will see what happens?
EDIT :
Yesterday when i re-install XP, i found a weird problem. After i choose C: as a partition to install, it format it and said that the "Setup was unable to format the Hard Drive. It seems that the disk may be damaged or corrupted.
After that, i restart the setup and deleted the partition and create a new one leaving around 500MB outta that 20GB and proceeded to installation. Then the setup went smoothly.
Hope that the 500MB i leave as Un-Partitioned might get corrupted. Is it so? Can i send it to RMA? I also guess that wasn't bad sectors. Is that right? Or just keep it with me without worrying about that 500MB?
PS Request
25-07-2009, 06:07 PM
Super Moderator
Re: RAM Issues
EDIT :
Bro...chill..chill....Do not think of RMA..so fast..gosh...
1. Try to read/write on the 500MB.
2. Run a Scan disk on the 500MB.
Though how is that 500MB showing up currently on your system..?
25-07-2009, 07:14 PM
Excessive happiness
Re: RAM Issues
@asigh
Since i unpartitioned that 500MB it won't show up in Windows. So i have to re-partition it to check it, right?
PS Request
25-07-2009, 08:52 PM
#19 (permalink)
Super Moderator
Re: RAM Issues
@asigh
yes..go to control panel >> Administrative tools >> Computer Management >> Storage >> Disk Management (LOCAL)
You should be able to assign it a drive name from there, and also format the sector so the OS can recognize it.
27-07-2009, 01:21 PM
#20 (permalink)
Excessive happiness
Re: RAM Issues
@asigh
Okay then. Now i leave around 9GB un-partitioned. Coz whenever i try to format it, it said "The hard disk drive seems to be corrupted or damaged.It was unable to format".
So i just leave it coz i am not gonna loose with that 9GB outta 320GB. Right.
And now a weird problem. When i switch on the PC in this morning, it took around 1min to boot into Windows. But this not same with yesterday, it just took around 30secs to boot into Windows. Why so?
Also my Hard-disk doesn't show up in BIOS and i need to re-insert the SATA pin in-order to get the system up. What's wrong?
EDIT : Installed KAV9 and scanned the PC. It showing that most of files in the HDD as virus, called Virus.HiDrag.Sality.z and it disinfects most of the files. Does this virus so harmful?
PS Request
27-07-2009, 07:33 PM
#21 (permalink)
Super Moderator
Re: RAM Issues
@asigh
Hey...
You have a really bad virus on your system.
1. Read up this link.
2. Try the methods they have suggested.
3. There is a utility mentioned at some girisoft website, try that. (Did not check it out).
4. Once you have downloaded all you need, remove your LAN cable and run the scanners, and utilities mentioned in (1) and (2) and (3).
5. Check again for the virus.
6. If 1 --> 5 fail, try a system restore. (To a point before the virus was rampant).
7. Check for the virus again.
If all fails, do a 100% clean format.
1. Pick all your data --- > music, images, xls, word documents, movies. Do not pick any executable, DLL, system file, registry entries.
2. Back up to DVD format. (Dont use pen drives).
3. Re-install the OS. (Format all the drives). Not just C: drive, all the drives.
4. Once you get the new OS, check again for the virus.
5. If (4) is negative, insert your DVDs. DO NOT COPY THE DATA to HDD.
6. Scan the DVDs for virus.
7. If (6) is virus free, dump the data back to HDD.
8. Check system again.
Just a side note:
I have not used Kapersky Virus Client, but I would suggest to upgrade to AVG 8. Its free and quite good. Else purchase a good virus client.
Best of luck BRO.
27-07-2009, 07:55 PM
#22 (permalink)
Excessive happiness
Re: RAM Issues
Just a side note:
Best of luck BRO.
OMG.. Thats fu(king insane dude. BTW Why not KAV and why AVG 8? I am pretty confused.
I purchased this KAV and been using this. But for past few months i didn't installed it as my system just laid down in my room just like a waste.
I think if i installed it and used, then i dont fall in this pit. BTW Will backup rest of the data's by today night and will do complete format.
What if the DVD is infected? Could i copy the files and disinfect them? Is that be ok?
PS Request
27-07-2009, 08:04 PM
#23 (permalink)
Super Moderator
Re: RAM Issues
I thought...Kapersky was not doing the job well, so suggested AVG.
YOU ARE TRYING TO TELL ME, THAT YOU HAVE BEEN ONLINE, WITHOUT AN ACTIVE/UPDATED/INSTALLED VIRUS CLIENT...???
27-07-2009, 08:07 PM
#24 (permalink)
Excessive happiness
Re: RAM Issues
I am in my Office and no Internet connection in my home as i am day-in/day-out person. Got it. BTW I said i only installed the KAV once i came to know that the system got infected.
BTW From my exp with KAV, i say its not that bad like u think.
PS Request
28-07-2009, 09:42 AM
#25 (permalink)
Super Moderator
Re: RAM Issues
Ok....
I never said KAV is bad, was just suggesting another virus client since KAV is not able to purge your system from the infections.
29-07-2009, 06:20 PM
#26 (permalink)
Excessive happiness
Re: RAM Issues
@asigh
Dude the problem with the HDD is almost over. But when i run the virus scan, things get screwed up. I accidentally clicked the option delete instead of disinfect and after a came back, i saw folders w/o any exe files. Coz they were all deleted instead of disinfect them . Please tell me a way to restore them back.
PS Request
29-07-2009, 07:42 PM
#27 (permalink)
Super Moderator
Re: RAM Issues
@asigh
Ok..
2. If (1) fails, there your Virus Client should have a 'restore option'.
Both (1) and (2) with bring back the virus infections. This time round, run the scanner with quarantine. If it is really bad, just do a 100% clean format, as I wrote above...!
29-07-2009, 07:46 PM
#28 (permalink)
Excessive happiness
Re: RAM Issues
Thats great idea. I'll try that.
BTW dude a 100% clean format is the last option and i'm on it. I am backing up the data's in a regular interval,say 1 DVD per day as i dont have much time now. So will do a full format once i finished back up the data's.
Thanks for the suggestion dude.
PS Request
